Water Cooling Custom PC
ghillie
Hi all, itching to make water cooled PC but am looking at services provided by others.
Was snooping around and found a few e.g. Aftershock , Scorpia, Illumirig
Anyone has any experiences to share or can recommend any service providers?
Rashkae
If you are looking to DIY, then don't get Aftershock.
ghillie
yes got hear say some negative sentiments about certain ahem, but not looking to self diy due to work and time constraints.
kennerv
I think,
Better to DIY everything. Perhaps start simple. Use flex tubes instead of rigid. Play around a bit then decide how and what you want to build.
easyxiaobin
But u are "itching to make watercool". so why looking for services?
Better do urself, i dont even trust most services, cos u wont know where might go wrong if it is done by them and sent it to u or not.
Do urself also helps u to identify where are the potential location of errors and etc
Rashkae
You say itching to make a watercooled PC but then you're not looking to self DIY?
Which one is it? Can you please try replying in comprehensible English?
SkyShroud
i think u r looking to fulfil ur little dream of having a water cooled pc right? if that is case, might as well ownself diy it as it will be more satisfying than looking at a end result
Fatfool
The Liquid cooling skillset takes time by the way. But the most awesome builds have always been done by individuals.
