Water Cooling Kits
tony_ong
Hi,
if i wants to change my current stock cooler to water cooler..
which will be a better choice? H60 or ThermalTake Water 3.0 Performer?
Thanks.
Yureak
Just whack h100i immediately... Dont go for an in between solution that will leave u wanting more
shadow84
Jus get a deepcool gammaxx 300/400 will do. No need till AIO cooling.
BTW, water cooling and AIO are different. What you mention is AIO nia. Water cooling is 1 step higher.
tony_ong
Sorry I meant AIO. I thought of getting a air cooler too but my fren recommend me to go for AIO.. :s22:
Why do you need to replace the stock cooler? Unless you are into overclocking
The fan noise of the stock cooler is very loud when on load.
Wanted to get something more quiet.
Hailgod
I think high end air coolers like the noctua nh-d14 is quieter than the h100i. A coolermaster hyper 212 should do fine though.
Yureak
The H100i is an in-between system. It's no different from the H60 or TT one.
How is a h100i the same as a h60??! Thats like saying the swiftech h220 or nzxt x60 are the same!
I beg to differ having owned both. Previously on h60 i was limited by temps so much so even on pushpull that i could only do 4.2ghz, with a h100i i can do 4.6 comfortably at mid 70s with the extra voltage headroom. Saying the h60 is the same as a h100i is saying a 120mm radiator is no different from a 240mm
That said i didnt notice his is not a K chip so he cant overclock so this might all be moot.
Im going for an EK setup at month's end though
Yureak
Air cooling is quieter but even for the dh14 isnt as good as those better aio kits much less custom loop. Plus its huge and might block your ram
Hailgod
The noctua is absolutely huge. A beast cooler. Quietest of its breed. I think it really doesn't matter too much which cooler you choose, just choose the one that looks better. A non overclocked system has no real need for a good cooler.
shadow84
Dun spend too much on something that does not benefit your rig by a long mile.
tony_ong
Yea thats y looking at those cheaper AIO.
How does the Thermaltake one stand against something like CM 212? Both seems to be about the same price... :s11:
shadow84
If you really wan aio, go for tt 3.0 performer, 2.0 performer, CM seidon 120M/120V, cheap range of zalman aio coolers, corsair h60. You dun need thick rads nor 240mm rads.
tony_ong
Hmmm so between the H60 and Thermaltake 3.0 performer.. which will be a better choice? or not difference?
ProWelfare
I went to google..
:eek:
Its really a beast!
shadow84
Jus go for the cheaper option. But, tt 3.0 performer shld b better in terms of quality. H60 had a few problems which i cant rmb. Read about that b4.
H60 uses coolit, square block whereas tt uses asetek, round block. Dun really matter though.. haha
