Soccer Ball
Suspended
- Apr 7, 2015
10tb running 45 to 48°C. Something I need to worry about?
I added 1 more fan still about the same.
Tia
Tia
..... the only way to lower HDD temps is to turn on the aircon.![]()
That's another way. I'm experimenting with letting this bunch of drives sitting at spinning idle to see if I can increase the lifespan of my drives.You can put the HDD to sleep when not in use. I use sleep after 20 minutes idle though you can set this to whatever suit your needs.
Gaming and my frequently used files are on SSDs so I only need to wake up the HDDs when necessary (a few seconds to spin up).
Tia
Tia
WD RED PLUS are 5400rpm drives
With 45 to 48°C, almost same as their RED PRO & ULTRASTAR 7200rpm drives![]()
