Weak wifi signal...
SBB8888B
My iPhone 5s always lost wifi connection when I'm inside my room.... My router modem is in the living room... . Anyone facing the same issue after updating to the latest os?
Any advise? Thx....
asriznet
Any advise? Thx....
Only your iPhone 5S having the issue?
Any other iOS 8 devices have the same issue?
Are you on 5Ghz or 2.4Ghz wifi network? try 2.4Ghz, helps with wifi coverage.
SBB8888B
I'm having this d link router that has both 2.4 & 5Ghz... It only happen to my 5s after updating to os8... Should I call StarHub or is it the phone itself got issue....
