weird problem on my 2yo 4790k build
raysusan
It has been 2 years
The comp will hang occasionally upon cold start up
After reset everything will be fine.
No other problem so far
Is this a sign of something going wrong soon?
jtjt00
Maybe memory, try remove 8GB. If still hang, swap to isolate.
raysusan
same:(
some time during game loading some time window detect error and will be force restart just after log into os
Encrypted11
If checking RAM try memtest86 for checking memory. Try at least 10 loops first leave it there overnight look for errors.
jtjt00
same:(
Maybe game installation or OS corrupted. When is your OS installed?
raysusan
That was 2 years ago....
Will try to view system log as muddle suggest
Most of the time hang during just log into windows
TanKianW
Might be motherboard. Had such problem in the past too. If you overclock, good to increase the voltage to keep it stabilized. If you do not overclock, can increase voltage by a bit to see if problem persist. actually, i find mobo less and less durable nowadays, always first to up lorry.
raysusan
View system log in event viewer
this is what i see after a hang
HaNZJTvkJEv7NviPBaCfbmouds1Z6sKaCrSMzXRrb_78yILpYePlVzSGjluRMiLmX00V2Cp3DXShjhcVzADNxvqwe083sySH-kd_VlWNm5bAvpk8jrzCQ3-dTBQEIR4JOWMpMv9-I0Ca6TJxnlRe3FiomQZ1r7J9zEMHxn-1SW-D_rdpjffSzvhgOiv25yRAcag1HyPCAKjas4fXu7qClAoYVPpj75whDUEa6MkkjvEHiYQzm-VhXzFwWgfJcHmtk5uPNF9V8BNfZ_jBzbgPc6lclGpIZAgBHcr6tKM2QiBCxibd86_fqlH7e2Dm8N7ZJ1L0--BhsNMBAEaiDQqH3YCTMiUHU7F_qWftqcwFtmw71gyXLj4Rd0ERcpqt6-PocnnKhZanabMcUBIwFevCh1q_iyjFETS-v82H2O90k49mkiDOT3iFXBIk3O52iwIPYImtq1URZIRFr7HnYlMzPlevxxz0IVyGiofmGeYfD6b77-aXiUDuNuS566b-JkVnI7tY1OUqY9FRN4IZ3RQrgmRBJFMTwWS27HOptTDeECThZtMuRM2SDEw9MyBV1M8lqhrUyEVrBHMfqYx5pSuybdpknUjdq__lwBfMp9hUfHYc6Y6IhZWA=w2372-h1334-no
does it help?
muddle
does it help?
Can try
https://answers.microsoft.com/en-us/windows/forum/windows8_1-performance/error-event-id-10016-distributedcom/130522d2-beac-4495-980a-65e1e3279901
raysusan
Reinstall fresh os
Run memtest86...no error
Resit ram
Still lag then hang after log in windows 10 or upon loading games
After reset will be fine. I am really loss now
Every time kena force reset
Kusanagi
what psu are you on? might have degraded over time, worst case scenario, mobo
have you replaced the mobo battery?
