Weird problem on my rig
ProGamer84
Anyone encounter this problem when you shutdown your com, after fully shutdown and with 3sec to 5sec ur com turn on back?? I'm on window 10..
If any know how to settle, pls guide me, as I'm not very good on doing the Vios setup or setting..
LiLAsN
Oh.. Yup. I encountered it once.
go into my computer right click properties then get into device manager. under network adapters find you driver right click and make sure that under power management tab you unclick let device start up computer.
ProGamer84
Thanks for the share. Will go in and read and see.
Tried ur method, but when I go to power management. There is two item was clicked. I try to Unclick 1 by 1 also same. And there is 1 was unclicked which mention magic something. As I now Honour awhile will be back home in short while.
