weird problem with booting with HDD
potshot
I have a SSD and another 2TB HDD (samsung brand)
my OS is installed inside the SSD, whereas the HDD contains data from my previous boot.
if I don't connect my HDD, I can boot up normally. however, i can't boot when I connect the HDD instead
jacktan87
have you set the boot piority?
if that does not help... if you don't have anything impt on the hdd... wipe the so drives
best is to post the error msg
go to bios and setup your SSD hdd as highest boot priority.
potshot
i already set the priority to the max but yet stil have the same problem
surispingly, i maange to found another drive to test (500GB seagate)
I plug it in, and it works wonderfully. Unlike the 2TB which has problem in connecting also
potshot
I guess i have to send to the service centre to wipe out the drive
or got any place in Sim lim that can help me reformat and diagnosis for free?
jtjt00
Many SSD upgraders make the mistake when doing SSD OS setup by having both SSD and old OS HDD connected. During windows setup, if MBR is found in old OS HDD, setup will proceed to modify it instead of creating a new MBR on the SSD. So your freshly setup SSD has no MBR and need the old HDD to boot.
The correct process should disconnect the all secondary HDD except the SSD and ODD. Connect back when setup completes.
xhlee87
The new ssd has no MBR still can boot?
potshot
okay here's the steps i take:
i have a thumbdrive with windows 8 installation inside
i mount all 3 hard disk, one of them was chosen to be the boot drive; SSD for this case.
initially the windows installation process is stuck at "setup is starting". I really waited for quite a while, went down to eat lunch then back.
after which, I took out both hard disks, except the SSD, and miraculously the setup is able to proceed smoothly.
So there are 2 HDD which I haven't connect yet; I connect the first one and it works. However, when i connect the 2nd one, it doesn't work. Even if i connect the 2nd disk only (with the SSD), it still doesn't work as well
hlots123
does "doesn't work" mean doesn't pass post/freeze & can't enter bios, or pass post but can't find windows to boot?
think u misread & got it opposite - problem is when old hdd is connected...
jtjt00
TS, re-arrange your sata connection. Connect SSD to first sata port and check BIOS again if SSD is your first boot device.
yusoffb01
Have a bootable windows installer ready. In windows remove the boot partition from old HDD, shutdown and remove old hdd
when u restart boot from USB then
Repair your computer.
Select the operating system that you want to repair, and then click Next.
In the System Recovery Options dialog box, click Command Prompt.
Type Bootrec.exe /fixboot, and then press enter
Type Bootrec.exe /fixmbr, and then press enter
Once u restart and can boot u can plug in old hdd
