weird problem with cpu, anybody here face before?
liewhl
i have a friend who just upgraded his com because he is facing some serious random rebooting problem with his cpu.
he replace and upgraded almost everything in his cpu except casing and case fan. According to him, the rig work fine for 1 week plus then the rebooting problem start to randomly occur again, but not as serious as last time.
can his casing or his case fan be the reason for the rebooting issue?
Hailgod
What about the PSU? some case psu stuck with case one.
liewhl
i look at his rig before and help him resit everything.
still reboot.
psu is not in build one.
the only thing left is casing and 3 case fan.
advise him change casing?
hengheng220
still reboot.
Can it be casing off on button got problem?
royfrosty
Check is there overtighten screws on the cpu itself.
2nd is check by unplug all 3 fans and see if it helps. If it does, swap out all the fans.
3rd if it does not help, check how old is the PSU, if it is old swap out for a new one. If it is just change then probably somewhere in the casing has been shorted. Reroute everything and see how it goes.
liewhl
psu brand new.
i resit the mobo for him before.
i notice that his the secondary/ slave power plug from the main cable for his hhd is actually resting on the casing . will is create a short too?
