Weird Problem with PC
Frozzy_
Hi bros,
Would like to seek help from you guys to have any idea what is this problem..
This is my situation..
I press the power button, Comp goes into POST.
As the comp is starting up, there's a weird beep sound that's longer than normal, monitor doesn't show anything. monitor goes into sleep mode.
Reset a few times, also the same. Off and on the power also the same, but instead this time of immediately on and off, I switch off the power and wait for a few mins before starting up again.. And suddenly back to normal.. I have this problem for quite long already..It comes randomly and I don't know what's the problem, because since it didn't bother me that much, So I proceed on using as per normal..
This is what I think it is..
I've been googling around, checking the mobo manual as well, suspecting might be my graphics cards problem.. but still unsure what causes it..
Any bros have any idea what is this problem?
Here's a link to that beep sound I'm talking about.
Vocaroo | Voice message
Alphas
Take out graphics card use onboard for a few days. If it happens then go check ram or mobo got stability problem.
Death4ngel
1 long 2 short beep is video problem.
Try taking out your graphic card, clean the contact area, and put it back in.
If that doesn't work, then try getting another computer's graphic card and see if it works; or put this graphic card into another computer.
Frozzy_
Okay. Shall try out the suggested methods. Thanks for the inputs guys. Appreciated.
