Well designed mATX cases?
jarred1223
Silverstone SG09/10 or TJ08-E
coyote
I prefer the cooler master elite 361 chassis. It gives you lots of hard disk space. Btw, for 2.5" drive, one should use those cooler master 2.5" to 3.5" adapter because that way, one adapter can put 2X 2.5" add/hdd and take up only a single 3.5" slot.
Elite 361 is not smallest though.
Nerd
That bad huh? Maybe if you specify what you don't like about the case then people can recommend stuff that more closely matches?
Can also check out Silverstone SG12, Precision PS07. Jonsbo U3, C3, V4,
Vulpix
Moderator
Moderator
Just the aesthetics of that Silverstone that made my hair stand. :s13: The Jonsbo ones look good siah. Saw a local distro also.
Nerd
Do note Jonsbo Ventilation generally is a afterthought. Usually zero intakes and at best 1 exhaust.
Vulpix
Moderator
Moderator
I was doing more reading up and realized new mainboards got this M.2 SSD thing where you can put a SSD stick on mainboard. With this I will only need 1 SSD and 2x 3.5" slots liao, no need 2x 2.5 anymore. Me is very outdated. :(
t258jgn
bringing out the big guns! I'm quite interested in this. Just wary of it's restrictions like gpu/psu size.
VGA length: 290mm
410mm (Remove HDD rack)
PSU length: 180mm
No problem for fitting
Gigabyte Xtreme Gaming GTX 980 Ti @ 287mm
Seasonic P860 @ 165mm
batuchka
Got case to recommend? Ideally can fit a typical Fury (non-X), don't think I'll be using one of those coolers with a sealed loop, just gonna use a normal hsf.
Fury Nano good to go but err prolly have to be careful of height of HSF :s13: By default is 80 mm front/rear possible to mount 2 x 120 mm front and side panel?
"Dual Chamber" so actually non modualr PSU no issue with cable management lol
2 x 3.5" + 1 x 2.5" on the PSU side and i think more on mobo side?
secure disks from below
Last built with this casing
FX 6300
Asrock 970M Pro3
8GB DDR3
Powercolor R9 270
Andyson F600M
yada yada
knightshaz
High Honorary Member
Nowadays really no mood to shop for part indivually :(
When my current desktop die will switch to small form factor pc, maybe just get one of the MSI Nightblades :(
