what BP machine recommended for home use?
qcy888
You can get a station if you want.
iu
klim668
Omron loh, not many choices out there. Or get the guardian one, cheaper. I bot it under $50 during promotion. Not bad, if not better than my previous Omron.
dereth
I'm using this one - Automatic Blood Pressure Monitor Atrial Fibrillation HEM-7361T
And bought this for my wife - the Omron Blood Pressure Monitor Smart Elite HEM-7600T
savoirex
omron. buy the model tat can use ac power direct, or if really need to be portable then use AA size...cos rechargeable battery inevitably will fail one day.
leonaheidern
actually if can wait buy from offical omron shop at pdd. wrist model 25 normal basic model 20 sgd. only button is Chinese can easily print a paper sticker and translate it if you don't like the chinese.
or shopee also got the from mainland china kind if you a bit more urgent for it.
want the fancy models then pay more lo
Read HWZ Forum Rules!
Can Or Not
Buy Omron… the cuff is softer and easier to wrap around your arm…
Microlife… cuff is very stiff like mine….
Bluetooth or not doesn’t matter… can record in your iPhone notes your readings or on paper… if you use android phone… sell and buy iPhone … ok
Can Or Not
Don’t buy the wrist model… it’s not accurate… very dependent on your hand position…
leonaheidern
the other one is quite troublesome haha. i had issues while on medication for irregular heartbeat so told to monitor by polyclinic system. end up really is taking 1ce a day in the morning before medication only instead of three times a day. but lets just say the meds prescribed worked after the second pill
Can Or Not
Got one watch with BP monitor Huawei…
luei74
Huawei D2 smart watch having promotion, can get around $33x, can measure your BP in 24/7 🙏🙏
