What is the different between NS infantry unit, commando unit, guards unit?
_eMuu_
in war time?
does commando chiong first?
does infantry chiong first?
the training?
they train the same things, go outside camp in a jungle.
SOC, IPPT. XXkm march.
daryl76
guards and commandos quite similar except lack of airborne
infantry is the one doing the usual fighting on the ground I guess while the guards and commandos will do more specific missions like reconnaissance and sabotage
Jack_Chen
Beret colour.
For what it's worth, bullets cannot tell the difference between the 3. It also cannot tell the difference between ranks.
1 x 7.62mm round to the head, everyone will immediately ORD liao.
Ah-Pin-Kor
different mission mah
cdo work in small teams, infiltrate into enemy territory for specific mission
infantry is main force, cannon fodder
xbidamanx
almost correct.. i just add on: infantry units usually kena tasked to hold grounds and cut off opponent... due to the 3:1 ratio policy, by logic usually wont send as offensive force but end up in fortified defence positions..
ground offensive fighting end up mostly armour and artillery units coz they have armour, speed and firepower..
_eMuu_
given a scenario.
lets say sg need to take over bukit timah hill.
we will send in the commando/guards first to capture the hill? den send infantry to guard it?
or we will send infantry first den comes the commandos?
xbidamanx
CDO and guards usually dont engage in hardcore fighting de, hence they rarely need to wear helmet. they need to do their specific mission and F off from the area..
xbidamanx
given a scenario.
i would still say CDO + guards to recce + take out certain key defence. then armour + artillery to weaken and finally infantry for the final kill when we have 3:1 advantage. enemy overrun liao then infantry take over defence.
notiboey
commandos do infiltration behind enemy lines with specific targets in mind hence the need to be airborne trained
guards are the elite infantry similar to the marines, they can do quick attacks hence heliborne trained
infantry are the pawns in the war, either get send in waves as wall against enemies or send in after bombardment by planes to clean up the field. either way, they get the worse shiat.
Phyber
Guards unit = Insertion via Heli-Rappel behind Enemy Lines, first to go in to clear strategic high-value targets, pave the way for main body (NS Infantry)
NS infantry unit = Main body. Do all the dirty work, Fight the main fight, most amount of people to sacrifice, die the most people.
Commando unit = Just wear red beret proudly and take awards after war ended (because SOF and Guards already done what they needed to do) :s13:
SOF = If i knew what they did, i'd already be dead...:eek:
Brehon
During wartime in a nutshell :
Riflemen defend.
Guardsmen counter-capture.
Commandos espionage.
CAShop
given a scenario.
U is got do NS or U FT
Generally the idea is
Commandos fights behind enemy lines. Drop them behind enemy defenses so they can blow up bridges or capture vital installation. These are the most dangerous missions because they get no support as they are fighting behind the enemy defenses
Guards are suppose to be elite infantry/undertrained/underpaid commandos. They do what infantry does and they are the QRF so if fighting starts or somewhere is getting attacked they will be activated
Infantry is the backbone of the army like all infantry units around the world they are the ones doing most of the fighting so if your scenario is taking Bukit Timah Hill. Assuming it is one objective in a bigger war probably a infantry or Armored unit will be taking it, Guards will go in first to do recce but that's after the airforce or artillary have bombed that place flat
_eMuu_
TS is RP. stay home and make sure everything is in order.
Bardiel
if war time
airforce + commando + guards go for the first blood
armour arti and combat service support round 2 (tanks,TUAO PAO and maintenance + top up amno)
then the final cleaner infantry
