When is Mi6 launch?
cscs3
Any of you guys have touch screen sensitivity issues when charging? The touch screen like lag or something. Only when charging apparently
Not sure it's the screen protector, software bug or hardware issues.
Oh btw, anyone updated to miui 9 already? Any stability issues?
Thisissue happen to a number of Xiaomi phone I happen to use. Redmi 1s, Mi4i, Redmi note 2.
Seem ok with Mi Max, Samsung s4, Note 4, s7.
Using same charger and USB cable.
If you use thse 2 pin USB charger, try to to reverse the 2 pin AC cable see if problem go away.
redname
I've used quite alot of phones but never had this problem. So it's a known issue on mi6 with no software fix or something?
It's a common prob lah, last time I got Samsung S2 have liao
vibranze
Any idea how to adjust display size? There's font adjustment.
The display look tad huge haha.
Sent from Xiaomi Mi 6 #Black using GAGT
Can be done using ADB command.
Display current display setting:
adb shell dumpsys display
Change the DPI, replace 420 with your own DPI:
adb shell wm density 420
Reset the DPI and size to default:
adb shell wm density reset
adb shell wm size reset
deckcard
I don't change resolution unless stock has that option becos it can mess up badly and alot of testing needed. Some apps may crash or text may not show up or looks weird so I just stick to stock and adjust text when needed.
On the other hand, using another launcher like Nova can do more customizations on home and app drawer like icons, size, gestures, etc. I use Nova now on all my phone to get the same look on all my phones :D
kenriku
Any tempered glass sp for this phone recommends? Tks.
I'm using the nilikin one.
Not full coverage so can see border, but edges are super smooth so it doesn't bother me. If not for the tiny mistake I made, the SP would have looked like it was part of the design of the phone.
Add a case with slightly raised edge and there's little chance the "unprotected" edges will get scratches.
Sent from Xiaomi MI 6 using GAGT
cscs3
20$ diff.
loses warranty/local set.
gain more storage.. :s13:
Another question will be that will you send a phone full of personal data in 64G or 128G internal over to a service person for a few hours or days?
amazingone
Uh basically any Internet connected device are sharing information to a service person, if you treasure privacy then it's best to get disconnected from the Internet.
Sent from freestyle using GAGT
