When is Mi6 launch?
LonelyMan
Anyone can share where to get good temper glass that covers the Mi6 nicely without the sides sticking out?
skyjammer
LonelyMan wrote:
Looking forward to $100 coupon that can be used with KSonline tmr for the $599-$100-$14.97 = $484.03
Is KSonline reliable?
Bought the unit on Sat nite.
The seller told me ready stock.
Sunday , he went mia and told me no more stock and come back on Monday.
Today , I went his shop but still no stock.
I will wait for 1 more day before cancellation
LonelyMan
I bought from KS online which is KS multimedia at Peninsula plaza or shopping centre. Spent 15mins to check the phone and everything is fine and with local authority certification and local set. I collected on Sunday about 2.20pm.
If you are asking about reliability of stock, then it is heng suay. As the small shop only holds so much stock and they will sell the stuff on first come first serve.
skyjammer
Hi LonelyMan,
From my view , it is not a matter of heng or suay.
Since I already buy for the item.
They should had the courtesy to reserve the unit.
Before I order , I already call and confirm got stock
Last minute tell customer , they got no more stock?
They ask me to go down today to collect.
After I reached , they play the same game again.
No more stock.
They tried to play customer out twice.
Is this the right way of doing business for small shop?
skyjammer
Add on , for note 7 "battery explode".
You can called it heng or suay as well.
For those sets with explode battery , it is just their suay.
Samsung should not recall back note 7.
Right?
garychengjw
Right?
Don't put in Samsung incident into this "no mi6 stock". You can cancel order if feel uncomfortable with the seller. Just my 2 cents thoughts
Sent from Samsung Galaxy S8 #CoralBlue using GAGT
skyjammer
just quoting it as example.
As the seller is selling mi6.
Just sharing my experience with the rest who is interested in getting mi6
LonelyMan
Hi LonelyMan,
No more stock.
Ok I see where you are coming from. Play out by seller when you mentioned you want to collect and they tell you to come over. Yes this is waste of time and transport money.
There is always this risk of having such sellers and Qoo10 is not going to do anything. If I Kenna, I also have to LLST so I can feel you here.
kenriku
Oic, thanks for your sharing. Any idea of any glass that doesn't have the edge floating? Or no such product possible?
Not possible cos the display glass is curved.
The full coverage kind either they give some kind of liquid that fills the gap so u don't see the white border, or else they colour the frame to disguise the floating edge.
Got bro share here before about this long long time ago.
Sent from Xiaomi MI 6 using GAGT
d4rk5oul
Anyone know of any working type c adapter that can split out to charging port and 3.5mm Jack to allow charging and listening to songs at same time?
androidmazon
this type?
https://www.alibaba.com/product-detail/USB-3-1-Type-C-Male_60691709779.html
