androidmazon
- Mar 13, 2014
Right, I've forgotten about it
Can I check if anyone on SingTel is getting VOLTE? I'm only getting 4G. China set on Global Beta Rom.
Sent from Xiaomi MI 6 using GAGT
Just got the MIUI 9 Global stable OTA, updating now...
https://www.singtel.com/personal/i/4G/service-featuresSingtel got VoLTE? My Singtel SIM never get VoLTE on my LG v20, Starhub one yes. Now the Singtel one on Mi6 also never have VoLTE.
You can press 5 times on the internal memory under the settings > phone information, you can see that provision of VoLTE toggle is "No", it won't stick even if you switch to "Yes". You can also get into the same menu by dialing *#*#4636#*#*
Update: Singtel should have VoLTE, but not sure if it is available as a VAS or default.
Can hoot Mi6 6GB/128GB export version 1 month warranty for $514 after voucher code on Lazada, Lazshop1111.
Ok asking cust svc got me provisioned for VoLTE.https://www.singtel.com/personal/i/4G/service-features
Yeah they do but apparently restricted to certain models. You can check the FAQ for the list. I'm gonna poke them and demand why... Lol.
In case anyone is tracking this, VoLTE not working on SingTel even after provisioned by carrier and switching on VoLTE on the handset. Global Beta 7.11.10.Ok asking cust svc got me provisioned for VoLTE.
But now I find this:
http://en.miui.com/thread-951467-1-1.html
Xiaomi not bothering to get VoLTE in most countries. SingTel also does not list any Xiaomi phones as supported in their VoLTE...
Nevertheless, shall try after 24 hrs and see how...
Am monitoring the price in TMall during double 11/11, price is expensive after discount...But a good phone to invest...
Just discovered, Android Pay only works on Global/China Stable Rom. Even for Global Developer Rom without root access and bootloader locked, Android Pay will not work.
That's because developer rom is rooted by default.
You all got experience data leak? My data keep bursting after changing to mi6. Usually my monthly usage is 7-8gb. After changing hit arnd 13gb for 2mths zz
got it. Thanks! No idea how the heck my google chrome usage so highDid you check security, data usage? Are the restrict data usage settings correct? There are two columns, one for applications and one for system applications.
Also under the data usage in Security you can see the amount of data used by each application. Should be able to identify which app used the most data.
