Where to get SCUF Controllers for PC
durant035
hi i am looking for controllers for my PC gaming. looking at steam controller, xbox elite. recently found out about Scuf controllers and i like it. anyone knows where to find it?
Gr1ngo
hey there, i got 2 scuf controllers for my ps4 and both broke down in matter of 2 months' of use. I bought them online directly from scuf website. Usually the small tact switches behind the paddles are what go haywire in scuf controllers.
I would suggest that you go for Sharq or Xbox Elite instead. I am using Sharq at the moment and their build quality is way better. They are using a different kind of tact switches which last longer. Just take note to reinforce the paddles that come with the controller as they break easily. For mine, I just cut out a piece of plastic with exactly the same shape as the paddle and glue them together.
If I had an Xbox tho, I definitely would be using the Elite controller - premium build quality and you can easily buy it here in Singapore at game stores.
2 cents.
