which gas water heater most bang for buck?
tankgunner
Mentor
KcSpider
Electric water heater too dangerous.
Prefer to use gas
Gas used to be much cheaper, electric more expensive
But buy City Gas will also pay even if not using, for maintenance
Both electricity and gas got its own dangers lah -- both equally dangerous
Electric water heater got more choices, gas heater less choices.
hardwaregone
Gas more lasting than electric.
Both don't last very well compare to instant.
If your house is not stable in electricity, very easy to short the heating element in electric. During the lighting storm periods, I'm sure many went dead.
In either case, get ready to either have a service or replace every 5 to 10 years.
I will personally suggest go instant cause makes more sense. :o
plasticpistola
thinking of changing to gas oso leh
gas got more pros than cons, compared with instant?
KcSpider
have been contemplating between the 2 for the longest time possible :s22:
have yet to install either :s13:
cold weather just tahan & use the cold shower
brrrrrr ... 🥶
Go old school lor -- boil water and pour into big bucket, mix with cold water until you heypi with temperature, use scoop to shower
Install instant water heater -- get licensed electtrician to do -- many places sell, easy and cheap to install, not expensive to run, plus got so many brands.
Got turn knob one
Got digital display temperature one
deathan9el
Honorary Mentor
too much effort laa .. :s13:
lazy to prep just to have a warm bath
btw u using what now? :o
KcSpider
Last time had central electric water heater, then the support start to fail -- we scared will hit someone's head
At that time decided whole house to change to instant water heater instead, each bathroom got one unit now. Ish good enough for us.
Another reason for change ish the water heater area always a bit hotter than other areas of the house -- anyway got more than a few reasons, plus got some cost savings to install separate instant heaters, and instant heaters don't heat up a lot of water so save money there also
popdod
Be a real man lah :s12:
Bath in cold water.
Guniangs then bath in hot water. :(
RyoHarusaki
Not about the cost.
Is about the safety
RyoHarusaki
So you using instant water heater but powered by gas?
