Why so hot la!!!
erwinrommel
My bedroom was 31C with 80% RH. It was like 41C based on heat index calculator.
Had to switch on air con to reduce the temperature to 25.5C before switching off. I prefer not to sleep with the air con on. I set the timer for the air con to run at about 3am and switch off at about 3.30 to cool down the room in the middle of the night.
XcoVar
Only when unbearable, switch on for about 10mins and off it. Sleep until wake up in sweat and on again for abt 10mins and off go back to sleep.
Got to save as elect bills not cheap
Remove the humidity by using dry mode. It will cool down the room to a comfortable level.
OutBreak
You are not scared your Aircon will be damaged? 10 mins might as well don't turn on. :LOL:
Linguist
Bedroom 1.5hp aircon blast at 16° also useless, earth will be too hot for humanity soon.🥹
Ans they are spending millions of dollars on stuff that will probably make the atmosphere and environment worse than to look into how to salvage the atmosphere and environment...
Might as well don't switch on just blast fan full speed...
chong18
You on and off the Aircon like this will use more electricity..lol usage is highest when the Aircon is working to cool down the room , after the right temperature is achieved, electricity usage will be lower liao
crandfs
Your aircon refridgerant leaking or a lot of heat from your PC, crypto miners, outside, west wall
XcoVar
It's the blower full of dirt thus affecting airflow. Oredi DIY washed it, everything is fine now.
jq75
Not stuffy ?
