Wifi antenna extension cable
Shahmatt
Can I use this extension cable to bring my PC wifi antenna closer to the router? Right now I am too far away and gaming ping is too high. Thinking of buying the 10m cable and wiring along the wall edge.
https://s.lazada.sg/s.5BeR
Besaid
If you are going to do wiring.. might as well use lan cable? Better performance for the same amount of work
wwenze
Maybe like me where can wire up to a certain point and then there's a wall or space in-between
Got it solved eventually 15 years later tho.
