Wifi receiving problem from phone
veltix
I'm living in a 2 room flat. Inside my room there's router. Here�. My phone received 5g in the room was okay but when move to Hall it change to normal. it lag abit, why and also weak to medium signal?
Sent from HUAWEI BLA-L29 using GAGT
Hafi
try switching to 2.4g or re-position your router in your living rm.
xonix
I'm living in a 2 room flat. Inside my room there's router. Here. My phone received 5g in the room was okay but when move to Hall it change to normal. it lag abit, why and also weak to medium signal?
[ IMG]https://i.imgur.com/mCHUA47l.jpg[/IMG]
Because,
2.4ghz - longer distance / normal speed
5.0ghz - shorter distance / higher speed
yusoffb01
you want fast or better coverage? Get 2 cheap dlink 868L for $10 each better than 1 expensive router
veltix
that router above mention us m1 give one when you sign up for 1gb Internet 39 dollars promotion
LiLAsN
That Asus router comes with unnecessary technology that most other devices do not use. the 'ax' line of Wifi bands. So no devices, especially your phone can utilize it. Based on location and obstacles around the house like thick walls and even placement of router beside a very strong electronic equipment like a TV and microwave can make it not able to cover the whole house.
Your best bet now since you already have this router, is you can buy or reuse an old Asus router, update the firmware and use the Asus Mesh AI functionality that makes your second router act like a mesh device along with your main router.
So just place the old/cheaper router somewhere in the middle of the house so the 2 routers can communicate and allow the second router to give you the same Wifi connection as the first one. Thus boosting the weaker area of the house.
The connection is the same as the first one. So your phone will automatically switch signals on its own. Plus, you don't need to register another Wifi on the phone. Cos, same network.
Either you use this method, or you have a long Lan cable from the Modem to your main router which you must then place in a better location in your house. It's up to you. Both methods should be better than your current one.
Koenig168
You can get a cheap repeater for the living room or switch to the 2.4 GHz bandwidth when in the living room (You should have two wifi networks in the house - 2.4GHz and 5Ghz).
Hafi
not every older ASUS router model can be flashed to the AiMesh functionality. If not, an alternative is to set the other old router as a bridge in AP Mode.
