Wiper squeaking noise
hoboonhua
My wipers are giving squeaking noise after windows coating. Anyway to stop the noise? I am using bosch aerotwin wipers. Thanks.
snipfer
1. Remove rain X
2. Use cheapo wipers
Sent from Xiaomi MI MAX 2 using GAGT
koolaid
Remove your wipers and wash them using dishwashing soap.
Dry it.
Apply 303 aerospace protectant in the wiper blades.
Let it dry.
Put them back on. No more squeaky noise n your wiper blades will last u for a few years. :(
hoboonhua
Yes. And to add on, just use water for your windshield spray. You will see the wiper noise reduced and gone in no time. Else, replace a pair of new wiper blade.
Already replaced new wiper still the same. Changed water to wiper fluid thought it would help but same..:(
hoboonhua
Dry it.
Let it dry.
Bro u tried these on coated windscreen?
ZWH rebmem
change wiper if hardened.
if no noise before coating, remove the coating.
then re-coat with other products
myviowner
It takes me about a week or longer to see the noise totally gone. Even change to anew pair of wiper does not work for me.
hoboonhua
Claimed insirance and replaced my windscreen becos of a hairline crack..solved the issue. Nvm going to do windows coating again. Thank all bro
koolaid
Ya used to be coated but that was yrs ago. Stopped coating it every since.
Anyway i Was at a client visit and we talking about cars. Told him about screeching noise with new blades even during a downpour when i was driving up to melaka to visit him. We went out to my car n he took out the blades. Clean it n sprayed the protectant on them and hookit back up. I havent changed my blades for 2+ years now. Still works like new n everytime when it rains, it seem to have that rainx effect too where the water will bead away when traveling above a certain speed.
He oso cleaned my dashboard n applied the protectant. Felt damn pai say. My dashboard looks nice n shiny n not oil even till today. I took his advice, just used a damp cloth to clean the wipers n dashboard once a month. Very effective n long lasting. Quite solid.
I asked around before n i think theres only a shop selling 303 in sg.
404_NotFound
Dry it.
Let it dry.
For my case, I use washing detergent. Just need to make sure it doesnt touch the paint.
