tingar1
Do all earbuds come wif sensor that detect whether it’s fitted properly in ur ear? I hv the Samsung iconx, keep cutting off when I tilt my head. Super irritating.
It's certainly not in all earbuds but Samsung has provided guide [ Keyword: Samsung iconx fit sensor | P.s: can't post url ] about how to make sure its a proper fit so you can don't encounter complications during your session. :)
hoks
The sensor itself is the complication:s13:
If I decide to change to another this will be the reason.
Jlyong0008
I saw a review that creative air connectivity is bad. If phone put in jeans back pocket, might get intermittent connection problem
Posted from PCWX using ONEPLUS 5T
Bluetooth works best when there is line of sight. It is quite difficult to get a signal through our bodies. I tried cupping my ear buds with my hands (anker liberty sound core) and the signal got interrupted. Can't be helped. Is physics.
lousydrinker
Ok ok. Sorry for being a noob. Haha
But sometimes even my phone is in front, I have slight connectivity issue or stutter issue as AbuNene mentioned
Apparatus
That's because traditional Bluetooth connects from one earbud then to another.
If your earbuds have the Qualcomm's QCC3026 with TWS+ it allows both earbuds to connect simultaneously, hence, reducing connectivity issue. Too bad only works for handphones having SD 845/855 processors
FYI, OPPO O-Free and Mavin Air-X earbuds come with the QCC3026 chip
Downloader
Those who bought Pamu Slide, appreciate if you can give some review or feedback of the good and bad and if it's worth to buy despite the cheaper crowdfunded price.
Recalled reading one of the earlier review that while driving, a little bump will engage the buds as it is not tight while in the case thus disrupting whatever existing BT connection in car e.g. BT music. I use Android Auto which by right don't allow a second BT audio/handsfree connection so perhaps it won't affect me. Wondering if this only affects the earlier production batch.
ksksksks
Got my sabbat e12 from Lazada. Fast shipping as it was from a Singapore seller
Having tried earbuds like 65t, AirPods gen 1, 2, senheisser momentum, many Anker wireless earbuds like liberty and mifo. This is very close to senheisser momentum.
The downside would be the lack of bass.
shinoku2
Still waiting for mine as it was in the 3rd badge,had some concern as there are alot or bad reviews on microphone, not able to operate and get etc.
Will update once I receive my unit hopefully by next week
shinoku2
Which seller and how much did you get it for?thinking to get it as well.
ksksksks
Sabbat E12 True Wireless Earbuds, Bluetooth 5.0 Wireless Headphones Deep Bass Stereo Sound Noise Cancelling Sweat proof TWS Bluetooth Earbuds, Built-in Mic in-Ear Wireless Earphones with Portable Qi Charging Box https://s.lazada.sg/s.UjpS
Same price from taobao but I see china sellers on Lazada selling cheaper. No idea why
ksksksks
By no means they can fight with the senheisser momentum but the comfort and fitting is way better for me.
For the price I think worth it and it comes with wireless charging and USB c charging. If u compare it against AirPods 2 w wireless charging - 299 sgd
Slayer1
so far still is Creative Outlier Air better in term of sound and pricing
Not to forget support.
I had some issues on my Outlier's micro-USB charging port which was working intermittently.
Emailed Creative Support and they sent a courier to collect it and sent a NIB in 3 days time by courier.
Excellent service imho.
S1
stiffzzzz
anyone can do a fast recommendation on wireless earbuds to buy for under $30 budget for today's 7/7 sale?
priorities are good sound quality and comfort when using for a long time
is ZNT D06-L worth it? seems like overhyped
I bought a pair of wireless earbuds recently for $25.00, looks very nice but the sound quality is so-so only. Don’t think can compare with the high end models. Comfort is ok though. I think you it’s better to pay more for a brand name set if sound quality is a top priority. Otherwise for normal use should be ok if expectations are not high.
ParkJinYoung
Sent from Google PIXEL 2 XL using GAGT
polowalrus
Received mine too. I felt that it has slight bloat in bass though.. and missing mud and some highs. I adjusted by EQ to lower bass and boost mid/highs
