Snoweagle
Yes. I have already say at the beginning that E8 has the best sound of all the TW that i have used.
Glad to have so many agreeing with me!
It really is. I've Earin M-1, then AirPods and now the Beoplay E8. Do you believe that the AirPods sound even better than the Earin M-1?
Gadgetfreakloh
Earin m1 needs aptx to sound good. If using iPhone will have no advantages. Dun really like Airpods as is opened type. Btw I dun use Earin m1 now as right kept skipping. Actually waiting for m2 to try.
ZacoLee
Sony vs Jabra
Hi,
Just wondering if anyone can provide some comments on Jabra Elite 25e vs Sony MDR-50BS? I am thinking of getting either of it, but not sure which is better.
Thanks!
doki81
65t really have a long battery life...I find that it have better sq when pairing with my op5 which run on aptx...v30 like not very good pair..
Sent from LG-v30 Plus From Your Heart using GAGT
Snoweagle
I bought AirPods as it pairs and functions most seamlessly with iPhone, obviously. But being open type I can also hear my surroundings without any settings and plugs in and out of my ears just like that, no need adjustment. I bought the E8 to replace my Earin for isolation and sound quality.
The Earin M-2 should be a big improvement over M-1 but I suppose sound will still be the same.
Gadgetfreakloh
I actually liked the sound of M1 which is very neutral. So I just hope that m2 will not have connection issue and also got mic and touch control. But so far not sure when launching and as they just got acquired by another company.
Gadgetfreakloh
V30 also aptx and aptx hd. I found v30 to give very good audio output to my tw ear buds.
doki81
Erm...I only have 2 tw for now..one is elite sports..one is 65t..find 65t..high is too bright..use app to adjust ...same..now not sure if I shd audition E8...
Snoweagle
It was said the M-2 is similar to AirPods, which is individually connected to the main device, so should be a lot more stable. Ever since I got the AirPods, I've given up on Earin.
Now I'll just use the AirPods and B&O E8.
mathew_soon
Those asking which purchase is better, it would be good to try them out first yourself.
Like me, I find E8 lacking for the price you pay. Elite sports suites me for sports I am doing. But it’s just me.
Go and try it before you buy and decide base on what you want to use it for.
I just retried the E8 and I am not going to touch it. The sound signature does not suite my use.
I am waiting for Active Elite 65t to test before making decision.
Snoweagle
What Matthew said is very true. Expensive or high-end earphones doesn't mean it suites everyone or even the majority. Everyone has different requirements so best is to try it out yourself and also check out the specs of the product before making your purchase.
daniel_83
I get interference (no sound on left side) when I'm near bus ez readers and when the MRT door is opening/closing in the tunnel.
Sent from LGE LG-H930 using GAGT
doki81
e65t?
