Remless
Though the app I can connect I don’t see the Low latency mode leh (i chat App Store already the latest) maybe the Low latency mode only for android?
But I have one issue I was using both size (originally left 100% and right 95%) but by the time I finished the right is indicated as (in the app) 0 and yet the left still 100?!
First, gratz on finally receiving the earpieces. The delivery took like... 20 days+?
For LL mode on appstore version, have leh. The '...' on top right corner.
For the battery drain on one but not in the other, refer to the user comments in scarbir's review site. One of the user encountered exactly the same scenario. It has to do with your usage pattern.
"The issue I've run into is that, after disconnecting the earphones from my iPhone (whether or not I press both earphones until they disconnect/blink red) and waiting some period of time (anywhere from a half hour to a few hours, I don't think I've checked after less time), when I reconnect the earphones, one earphone is at 0% battery while the other is almost full (usually the left is dead, but it's also happened to the right) . Note, this is without putting them back in their case between uses."
https://www.scarbir.com/tws/fiil-t1x-review
How to do I know how long to charge when there is no charging indicating light on the buds only the 2 red lights outside so when I put my buds inside and I plug my charging cable in I Donno the red colour led is indicating what?
Any bro can help?
The 2 red lights are simple notification lights. When they are on, that means the earpieces are charging inside the case. When they are off, that means charging completed. You can only see the battery percentage of the earpieces in the app. As for the remaining battery % of the case, there is no indication.
davidwong
Thanks bro
Where did you download your app (iOS version)? I did by going to App Store and search fiil + global, v2.3.6
Remless
Thanks bro
From appstore. Same version, v2.3.6. There is triple dots on the top right hand corner to access to more functions like easy mode, low latency mode, etc.
Lemme take a pic.
davidwong
My set right bud got issue it won’t charge even I left it overnight still 0
Lemme take a pic.
Remless
The right notification light should be light up when its charging. Check the placement of the bud in the case if its not lighted up.
If its lighted up and still won't charge, you might need to contact the seller for support.
Remless
I dont mind lypertek. But is there better ones at the price range and below?
If you are on tight budget, soundpeats truedots may be an option. However, if you can pay slightly more for better features, I would not advise you to buy any qcc3020 based earpieces (ie, those that currently support aptx) if you want seamless connection and usage found in earbuds like galaxy buds, sony wf-1000mx or the apple airpods.
Qualcomm had announced new chips that promises better seamless connections and will include ANC/ambient mode in the chips, if you can wait.
If you cannot wait, fiil t1x can be an option, or the new qcy t4 (very budget earpiece that promises to have seamless L/R switching and app support also, but lacks volume control).
davidwong
I have contacted the seller and she had gone through with me the reset process the right bud totally dead.
She asked me to send back to China (on my own dime) then after check 1-1.5 month they will send out another one so back and forth about almost 2 months but they can’t sent to Singapore I need to arrange my own freight (again on my own dime)
Alternative is for me to send back (on my cost) then ask for refund and then to bid a new one which again the shipping (on myself again)
Remless
Goodness... which seller is that? Can screenshot the page?
I bought from this one.
ksksksks
If u get from China seller in Lazada still can send back without forking out the fees.
Pay a bit more for local seller can get next day
NurSyaf1
Samsung Galaxy Buds+
I just got the 2020 version of Samsung Galaxy Buds+ from Shopee cause they're under the Million $ Discount!! If you get the white one (like me lol) it's only $199
so far so good guys, i can use it while im running and it doesn't drop out
Remless
You should have got it from carousell. There are so many people selling brand new sets of galaxy buds+, all with 1 yr local warranty.
The prices now are stabilising between $150-$160. Any lower is snapped up in minutes.
(Saw a $140 the day before, when I went into the ad, its gone liao).
And I don't think anyone should use a bud with only ipx2 rating for runs.
Lol. Just when I am saying, another one appear.
wwh5210
Received my Anker Soundcore Liberty Air 2. Have been using it for a few hours and so far so good. Made 2 calls and my friends told me the voice is clear. Nothing to complain at this price ($105 after discounts) lol.
