justln
Buds is definitely not worth it for $269, Galaxy Buds much cheaper. Add a bit more can get active noise-cancelling Sony WF-1000XM3, might be cheaper during sales.
Gadgetfreakloh
I sold a new bud + for $130. So it is possible to buy at that price.
DigDub
I found that i prefer the buds than the buds+. I prefer the sound as they sound fuller. Only thing better on the bud+ are battery life and better mics.
I prefer the original buds sound also. They sound more neutral while buds+ sounds more v shaped.
meowth82
Anyone using Soundpeats Truenginer 2 or SE? How is the review? I saw Lazada got promotion. Truengine SE only $54 and Truengine 2 only $68. But seller is from China.
DigDub
Got truegine se. Quite bass heavy sound.
Beefsteak
Any wireless earbud/earphone to recommend specifically for running/jogging.
Something which I can still be able to hear ambient sound/surroundings.
Budget in the region of about $100
*PS: Just need it for running/jogging use only.
ichinisan
Creative Outlier Air
fireduke86
Perhaps you can take a look at https://shopee.sg/JLAB-JBuds-Air-Sport-True-Wireless-Earbuds-i.236984662.3220378075. I watched / read pretty good reviews of it and the Epic Air Sport and I am thinking of getting the latter. However, it seems the Epic Air Sport isn't available here officially.
davidwong
Seems fitting is not optimal best to go to store and have a fit testing before buying
Creative is a good choice. affordable with pretty good specs (for running/waterproof/sound quality). support local!
disclaimer: I don't own it but read good reviews about it.
darr
Any in-ear will not give good ambient sound awareness....If I don't run in traffic areas I will just wear in-ea.
If cycling or running in traffic I will wear bone conduction...nowadays China ones are pretty good and no longer just Aftershokz monopoly.
nwh_sg
are you using any china bone conduction headphone? pls intro if it is good. tks.
I am using Aftershokz air and I like it. Thinking of getting the aeropex.
vofzxy
