roronoa_zoro
Finally this arrived. Really quite impressed with the sound
DigDub
New update for galaxy buds live. Sounds clearer and less muffled.
vofzxy
receieved my taotronics 79
not the easiest thing to pair, like the tronsmarts
got it from ministryofgadget on shopee. they had a flash sale @$215 then I used $20 shop voucher and $10 shopee voucher to reduce to $185
FOMO sia
its back to SGD 295
dolphina
I have the T1x not bad. And though not ANC, but right fit not too bad in filtering out ambient sounds.
Thinking to consider the newer T1xs or soundpeats 3se. Looking below 100sgd budget for good sound and buffer ambient. Anyone can advise?
dolphina
Thinking to consider the newer T1xs or soundpeats 3se. Looking below 100sgd budget for good sound and buffer ambient. Anyone can advise?[/QUOTE
Just realised T1 pro is about to released on 9.9 in china. Anc and eec wor. Wow
vofzxy
https://www.engadget.com/klipsch-t5...rbuds-specs-price-availability-110014906.html
https://www.klipsch.com.sg/products/t5-ii-true-wireless-earphones-mclaren
spec sheet ---
https://f072605def1c9a5ef179-a0bc3f...-Wireless-II-Sport-Mclaren_Spec-Sheet_v03.pdf
STYLE -- In-Ear Monitor
DRIVER DESIGN --Dynamic Moving Coil Micro Speaker
DRIVER DIAMETER --5.0 mm
MIC/REMOTE cVc --8.0 Quad-mic
FREQUENCY RESPONSE-- 10Hz-19kHz
NOISE ISOLATION-- -22dB
INPUT CONNECTIONS --Bluetooth
BATTERY (EARPIECES) --50 mAh
BATTERY (CHARGING CASE)-- 360 mAh
BLUETOOTH® SPECIFICATIONS Version: --Bluetooth 5.0
Profiles:-- A2DP 1.3, AVRCP 1.6, HSP 1.2, HFP 1.7
A2DP Codecs: --SBC, AAC®, aptX®
Range:-- Up to 10m (33ft.)
Input Rating: --5V DC, 1.0A
Battery Status:-- iOS & Android Battery Status Monitor
ThinkMe
fb3909b1b0b6482cb1f7ea754f59b0b1
7d2a87c2f3f44722a3cafb446f931e78
