samsungXP
Get from carousell $100 brand new sealed
Sent from Galaxy Note 10+ using GAGT
Gadgetfreakloh
Read that Panasonic ANC is one of the best in the market. Is that right?
Panasonic ANC is good. Not the best.
For the price is super value.
The fit are comfortable at least for me. Go try yourself at connect it. I am using my own JVC spiral dot tips to try.
EmPtYsOuLz
My earfuns from the initial indiegogo campaign died less than 1 year from light usage
I'll be hesitant to go for them given the limited warranty
chesterqw
Why get the earfun free pro when it is a badly tuned fiil t1 pro, while being more expensive?
trenzterra
I just realised galaxy buds pro is ipx7... So got it as a jogging pair. Carousell price is about 180 to 190 right now.
However, I still prefer the jabra 85t for daily use. Galaxy buds pro no shortcut to disable ANC, need to go in direct to the app. The ANC is also much lousier than the 85t. Sound quality wise, about the same. The GBP has a smaller case but wireless charging can't work on normal charging pad... Need to have those smaller kind then can charge.
DigDub
Unfortunately jabra doesn't support left side single bud usage, else would have gotten one to try.
chesterqw
but the jabra 85t don't get nerf-ed just because you aren't using a samsung phone, and it has Bluetooth multipoint.
