PaulLevesque
Maybe u can consider going to audio shops like ConnectIT to try
I went to a few shops to test out a few demo sets before settling for a SoundCore i3. IMO it has the "best" overall sound for the $79.9 price.... Problem with it is the left side earbud unable to sit in properly. Not sure if it's due to oily skin or what.
Anybody has any solution?
zhihe1996
Not using ur earbuds but i switched to Spinfit eartips a while ago and I find the fit and comfort to be way better for me than stock eartips.
PaulLevesque
And I thought i finally ended my quest of searching after getting that earbuds... Now gotta start finding a good tip for them too...
Do you get your tips from a physical shop? If so, where can i go for testing?
zhihe1996
Got mine from ConnectIt , dont think can test eartips though due to hygiene issue. I think you can show your earbuds to the employee and let him advice you.
wwh5210
Gotten QCY T18 to replace my 1.5 year old Ugreen earbuds. Sound quality is decent at this price range. Average mic performance. It supports multi device connection with Aptx Adaptive codec. Furthermore it has an app for customization. Really nothing to complain at this price range. Got it on Lazada at $38.
xRenol
Any TWS earbuds recommendation for sports because my current one got no sound on the right earbud? I do not plan to spend too much as I feel the lifespan of earbuds used for sports does not last long.
Budget: < $100 (if < $80 will be better)
Material: Prefer not those rubber feel type as it will get sticky over time
Sound: No preference as I am not an audiophile
Feature: On/Off function
Thanks.
peaceheart
Thanks.
What kind of sports? I always wear only one side when doing sports for environment awareness.
My thinking same as you so will get cheapo tws too. Currently using edifier x3 for sports
DigDub
Firmware update for Bose QC2. Allows seamless independent bud usage now.
Henabi
Thanks.
Redmi Buds 3 Lite
