caterham7
Hello, any budget earbud (<$30) which is good for calls and with multilink?
I using qcy t13 for zoom but other party cannot hear me well. Thanks
most wireless earbuds, especially budget models, have poor quality microphone
if possible, consider using wired earphone with mic
i bought apple earpods [usb-c version] for below $30, great for teams and zoom calls
note: wire is thin and flimsy, need to take care not to accidentally yank it
Sambuca78
Thanks, how about liberty 4nc?
Henabi
If you just want a wireless earphones for calls, and you dont mind one sided…
Go for Jabra Talk 15 or Talk 5
Basically the best budget mono earphone for calls and can multi-point with 2 devices.
gregory_choo
Thanks, so far i only know 4nc has multilink but seems overkill just for zoom calls.
Not sure if cheaper soundcore models have multilink and are good for calls.
dont limit yourself to zoom calls.
it is super goood if you wear it on bus, mrt or aeroplane. the anc will make you think that yoi are in a highclass car.
Sambuca78
Seems like Honor Earbuds X5 has multipoint and is good for calls but battery life is just 5 hours.
Anyone have any experience with Honor Earbuds X5 ma?
Thanks!
anthonygreenisreal
Got this for $68 from Mr Mobile. SG warranty set paid in full using cdc voucher. By far the cheapest around with other places still selling at $80+. This model likely being phased out and shops are clearing remaining stock.
redwhitemobile selling same price as well. i got it a few months ago.
