rayban
I buy around 265 if I remember correctly
finally jumped onto the wireless bud wagon with the elite active 65T
So far, my 2 cents:
- fuss-free and intuitive setup / pairing with my apple watch within seconds
- no noticeable lag
- pretty comfortable fit for running
however, i personally still find the price (> $260) a bit too steep for what it's worth.
Skyline34_
i got mine at 209 thru an in-house rate - hence was willing to pull the trigger as retail (after discount codes etc) was in the 260+ range
rayban
It seem q0010 stock still sold out. Anyway the it 2 year warranty on hardware?
Albedo
So far, my 2 cents:
- no noticeable lag
Use it more often for better ROI then.
Matrock5
can you explain more about the in house rate etc? how come you can get at such a good pricing man? Membership points rebates?
Matrock5
Just checked that Mustafa is selling at a attractive pricing than Challenger
clock_ED
Guys, any budget ones for running? Preferably <$45?
Would prefer wireless earbuds (those 2 separate pieces ones). :)
patryn33
does elite 65t support aptx ah?
google is like half half leh.......
See specs
https://www.jabra.com/_/media/Product-Documentation/Jabra-Elite-65t/technical-specifications/Jabra-Elite-65t-Techsheet-A4.pdf
List of supported products
https://www.aptx.com/products?field_aptx_type_tid=483
xecuter
Hello guys, thinking to convert to true wireless soon.. After watching so many reviews, still can't decide. Jabra Elite 65t or B&O E8 better ya? Prefer E8 design.. which one has better SQ?
rainbowmonster124
Need some help,my left earbud for Jabra Elite Sport cannot turn on. It’s brand new. Anyone experienced this problem before or know how to fix it? Thanks
storm913
I'm using Pamu backed during Indiegogo, I like the fitting and could even sprint with it. But the battery charge is terrible. If I fully charge the case plus buds, and didn't touch it for 2 days, the battery is fully drained..
edit: Anyone used the Aukey EP-T1? Can't find much reviews on it.
numan108
Did you tried putting it back in the case and charge for awhile and then try it.
Alternatively you can pressed the button or -ve nearer to the tip and see if the led showed green.
QUOTE=rainbowmonster124;116177564]Need some help,my left earbud for Jabra Elite Sport cannot turn on. It’s brand new. Anyone experienced this problem before or know how to fix it? Thanks[/QUOTE]
Snoweagle
Anyone using comply foam truly wireless for their earphones?
Any reviews on it?
Have been using those for my very first pair, Earin M-1 and it’s very comfortable, isolation is also very good.
But after 2-3 months of almost daily usage (sometimes less), have to replace it. I ordered it directly from Comply USA so in the end gave up the hassle and bought AirPods, then later B&O E8.
