josephkjc
Yes the case can close. It’s a short type of comply foam.
Available from Stereo https://www.stereo.com.sg/shop/acce...-truly-wireless-twx-standard-3-pair-pack.html
can you close the case when using the comply foam ?
previously somone wrote if you use other tips, you cannot close the case to charge it,
where did you buy the foams from ?
xenocide
anyone tried havit g1 and the indiegogo aria sports earbuds?
i have the G1
its pretty good
Nice seal and fit
i use it for commute. it has less drops and skips than my previous PaMu Gen1
The usual places where i experience interference with PaMu are better with the G1.
Battery life is better than PaMu.
I got it from aliexpress sale. Didn't get the wireless charge version.
Jkdada
i have the G1
its pretty good
Nice seal and fit
Thanks for replying and helping out :) Was looking at earbuds at 150 price range looking at options like crazybaby nano, sudio niva,havit g1 but i think ill go for havit g1
Greenworm
Anyone knows the difference between the Erato apollo 7s and the their new Verse?
Why is the Verse newer but the Apollo cost more uh?
Gadgetfreakloh
Verse is lower cost version and do not have Aptx. Also master is always right side. Apollo can choose master side and the sound are way better.
greatgreenman
Finally got my elite active 65t today. Sound quality is excellent and they definitely won’t fall out of your head that easily unless you’re head banging at a death metal concert. Damn thing is the tips that come with it aren’t very comfortable. Anyone know if Westgate stereo sells comply foam tips?
storm913
Is there any earbuds yet that prove good connectivity on par with airpods? But at a cheaper price?
chenghui
Which truly wireless would be good for swimming (public pool) ? I have my eyes on Jabra Elite Pro, Bragi Dash Pro and Samsung IconX (2018). However, there were some comments elsewhere that said that bluetooth connection doesnt work well under water, but those were connecting to a phone on land, but if the TWE was connected to the device underwater, would the same issue occur?
If so, i would have to narrow down to those with internal storage, namely Bragi Dash Pro and Samsung IconX. In addition, how do the sound quality between the 3 compare?
Gadgetfreakloh
Only bragi dash pro is good for swimming. BT does not work well in water. That is why they is 4gb build in storage for stand alone music player. Icon x and Elite pro are not certified waterproof.
