peanutgood18
OMG ready to buy it!
was confused which one I should buy... now i c!
https://blog.comparee.com/uncategorized/bose-soundsport-free-bo-play-e8
talonn
Does one side audio disxonnect occasionally?
If it more stable than x-mini,,I'll be motivated to change to this one.
If you want to reconnect after not using it for sometime it will have some drop out issue.
But once you refreshed the connection (by turning off and on bluetooth), it solved the problem for me. So far I am happy with it
Anything_Whatever
By the way where to buy the bose soundsport? Amazon doesn't ship that item to sg
Don’t just read reviews or listen to someone that says it is excellent...
You should go down to some shops to try and see whether you like it or not....
You can try Stereo @ Westgate... selling @ S$287
https://www.stereo.com.sg/on-sale.html
kazuki666
I found something a new trick for the xmini earbuds. This morning I took the two pieces out from the pod, strangely both pieces are not turned on which usually by default they do when I take them out from the pod. I on the right side first, followed by left. They paired up smoothly, and pair to my Sony player too. By surprised I did not have to adjust the right piece to certain angle before both connect seamlessly. Took bus and mrt, walk in a mall, on the street, all no drop off at all. :)
Sent from Xiaomi REDMI NOTE 4 using GAGT
quiliner
Dropped by Stereo recently & found out that Comply have remove Jabra Elite 65t series from their list of earbuds that are compatible with Comply’s TWL foam tips as the design of the Elite 65t nozzle doesn’t “catch” the foam tips’ stem securely (& causes users to have foam tips stuck in their ears while unplugging).
Wanted to get the SpinFit instead but also found out the length of the SpinFit ear tips causes the main body of the Elite 65t to jut out much more than the stock tips thus losing the good seal. In the end didn’t buy anything...
eekee
I meant will there be occasion when listening to music the one side temporarily no sound for 1 second or 2?
Bardiel
I will order 3 sets tomorrow to fit in for the free delivery.
Once item arrived i can do meet up collection
weekday 6.20pm serangoon mrt onwards as i travel upward to punggol. latest 7pm punggol.
PM me if u wanna tag along the order. Pls pay full sum ( to avoid aeroplane buyer)
audioenslave
anyone keen to try out earin m2 earphones can pm me. with invoice bought may 2018.
decided to stick with my shure bluetooth cable gen 2.
Akky85
Hi guys, seem like there are many experts at earbud here. Not sure if anyone is using Jabra Elite 65t? Just wanna check for the charging case, what happen if i mono listen using the right ear in office, while leaving left earbud in case, does the battery for both become un-even? Or will the left ear bud be in a constant charging state and continue to drain the case?
Bardiel
i ordered 3 sets so got 2 sets spare. any 1 interested pls do pm me =)
