cowyblock
which of the following earbud should i choose?
which of the following should i chose? All the reviews seems good but i am having a hard time deciding, i only have a budget of 50$?
Soundcore Spirit Sports Earbuds by Anker
https://www.amazon.com/Headphones-So...p_ob_title_wld
SoundPEATS Bluetooth Earphones
https://www.amazon.com/SoundPEATS-Bl...42RCW38GVD9W3S
Anker SoundBuds Slim bluetooth Earbuds
https://www.amazon.com/Anker-Headpho...s_a_1_4&sr=8-4which of the following should i chose? All the reviews seems good but i am having a hard time deciding which of the following would you recommend?
doki81
save it up...invest on jabra elite better..
Sent from Samsung Exploding Not 9? using GAGT
cowyblock
Is there a shop i could go to try it? I never use a wireless earbud before that is why i wanted a cheap one to try first. would it be better to buy on amazon or physical shop though?
FljpFl0p
Just ordered the Sennheiser MTW on iShopChangi to be collected at the airport before my flight. It's $438 but there's a $30 coupon that you can use to bring it down to $408. Not too shabby.
iShopChangi also has the 30-days money back return, which I'm hoping it covers earphones. I think Sennheiser and other shops won't accept the return if you've already opened the box.
freshvibes
Does both the Elite 65t and Elite active 65t have any lag when watching videos? For YouTube, movies etc..
theaudioguy
Both models quite common to be found in major electronic stores. But if you want to test comfortably, can try Connectit at 313 Somerset. Spacious and comfortable to test the TW models.
Hii all, where can I test the Jabra Elite 65T and the Bose Soundsport Free? Which sounds better?
doki81
i dun think u wannt to try... where other people put in their ears...
quite disgusting leh... =:p
they will use alcohol wipe to sanitize..but still..depend on you OCD or not...if very OCD...even public toilet bowl you feel disgusted right..
doki81
is it this Stereo - The Headphone Concept Store @ Plaza Singapura? also i am going to udon thailand soon would buying there be cheaper?
why is udon cheaper?
vengence_angels
Anyone knows if Jabra SG recognise International warranty?
Intent to buy it from HK. Not sure if warranty will be valid here.
vofzxy
IP5/8 against water
IP6 against dust
Edit: uses NFC to connect... The staff connect for me sia hahaha
I sua ku dunno how to use NFC :s22:
Sounds pretty good
Quite bassy for my music... On Spotify
Listened to delicate by Taylor swift
And praise you ( purple disco machine remix)
Sound cancelling is good too
Sent from Sony G8142 using GAGT
