WhiteHunter
- Sep 13, 2012
I did. The best I have heard so far, and the only one that can sync videos on my LG G5 perfectly.
Sound wise, runner up I would say is the SP700N. 65T sounds worse than CKR7TW.
If you are looking for your first true wireless and you are not on a tight budget, it is a good choice.
which will you pick if not on budget, sennheiser true wireless, sp700n or jabra elite 65t?
