Wireless charging pad for Iphone X
Jinhyun
Are there other cheaper alternatives to enable wireless charging than buying apple's accessories?Thank you.
rvyne7
saw some 10+ wireless charger at Sim Lim not sure if its okay though :p
renfred89
The cheap ones are not good. Including those cheap and claims to support fast charging. Reason being the cheaper ones have lower efficiency. Efficiency is defined as the amount of input power gets transferred as output power and the amount of eddy current generated..
Snoweagle
My advise is don't settle for less, get a good one and don't have to worry anymore.
nicepal
