Wireless connection issue
osirisx
No wireless option found under network connections.
Only Bluetooth and Ethernet visible.
Is this an issue with the wireless driver?
Do I need to download the driver from the manufacturer website?
xonix
Is there anything under device manager > network adapter ?
Or device manager > unknown device ?
osirisx
Yes there are quite a few under network adapter, but non seem to indicate wireless
xonix
By the way you haven't indicated what sort of machine is this ?
DIY / pre-built PC or laptop etc ... some info will be helpful
If there isn't anything under device manage or network adapter ( control panel ), most probably wifi adapter is dead.
osirisx
It's actually an used Acer laptop tmp246m
86technie
- Is the Wifi switch turn on?
- Is Aeroplane turn on?
Suspect could be Windows issue, if Wifi switch is turn on.
Suggest backup any data on the PC and do a reinstallation of the Windows.
(Reinstall Windows is different from Windows reset.)
xonix
Ok, looks like your laptop ( depending on the variant ) could be using wireless chip from either Broadcom/Intel/Atheros. As I mentioned above, if there isn't anything under device manage or network adapter ( control panel ), most probably wifi adapter is dead.
Example:
xonix
You could try to replace the wifi chip ( bottom left hand corner chip with white label ) but might be easier to just get a usb replacement:
osirisx
Turned off airplane mode, but no option to toggle WiFi on/off
osirisx
Example:
Any reliable place to replace the adaptor? Sls or Acer Service center?
Otherwise maybe I'll get a usb adaptor
xonix
If you are not look forward to opening up the laptop and changing ( what looks to me ) the mini PCIe wifi card, easiest way is to just buy a USB wifi adapter that's supported on your operating system.
86technie
Wifi card very rarely will die, most often it is Windows issue.
If you want to make sure, you can download Kaspersky Bootable Rescue CD a Linux OS.
If after booting into the OS and if the Wifi can be detected than that means Windows issue.
https://support.kaspersky.com/krd18
osirisx
Just have to download that and boot via USB?
Kinda looks like an antivirus program to me?
86technie
It's a bootable OS, you have to download than create a bootable USB.
This tool is a bootable OS with anti-virus as well as recovery tool.
Useful for not only scanning virus but also can be use in other ways
like testing the PC hardware.
https://support.kaspersky.com/14226#block1
tsteo77
Most likely wifi chip overheat and die. It happen to my brother asus laptop which wifi suddenly disappear but appear suddenly while using lan port. Better bring to acer service center.
kandinsky
xonix
I recall having one old laptop, the WLAN was disabled in BIOS. Maybe can check that also.
Oh yah... I forgot to ask TS to try this ! (y)
Some laptops use FN + hotkey or mechanical switch which allows user to quickly turn Wi-Fi on/off
