Wireless IP Camera thread
geckoSG
Too bad MARIX is not at the shows as usual. Else lots of options to choose from their T series
chercm
is this good : Prolink PIC1006WN or Dlink DCS5020 or DCS5222 ?
any kind soul can advice ?
marixsales
How much is it ?
Hi,
You might be keen on our office's online T7837WIP promotion. Buy first unit @ $169, 50% discount on second unit. Breakdown will be around $126.75 per unit.
HD 720P resolution, 32GB MicroSD Card slot, WIFI, dual IR-Cut Filter, Night Vision. Easy to setup (Plug and Play). You can call us at 65623390 for more info
lightchaser
Hi,
apart from resolution , whats the diff between the T6835 and T7837 ? streaming wise on tablet and hp same ?
walkwaffle
I am using EDIMAX IC-3015WN, and it seems to have a good image sensor, wide angle and 720P
any alternatives that also have mp4 encoding and ptz functions too? Thanks!
dao
Just hoot an Aztech WIPC408HD from IT show. Didn't know that the power cable is so short. Cannot reach the HDB ceiling where I want to mount the camera.
My current panasonic IP camera has a very long power cable that has more than sufficient to reach the ceiling.
Is other brand like D-Link having a long power cable that can reach the ceiling (normal HDB ceiling height)?
slurpy0099
Hi,
I can do the wired kind. It's a lot of work trust me. If you really chose the wired kind, let me know. As for DIY wired kind, I would advise you to pay me to do it for you. PM me if you wish to do it.
Can you advise your quote? Do you have any website on more info?
otake1982
Hi guys, I'm looking for a easy to use IP camera with an android app to monitor my parents at home. I saw Synology website but it seem they are into those surveillance solutions with hdd etc. I do not require recording so am looking at Dlink so far. Is that something Mrixsales carry?
awful999
what class of microsd card should we use in IP camera
Hi guys,
Can I know do we need to use CL10 microsd card or just a CL4 card will do ?
thanks.
Fuzzywuz
will be great you can share here a typical set up with quote so that other bro interested can benefit too. :s12:
Typical for one point is $100-$150 excluding material cost. $100 will be typical small shop < 1000 sqft. If multistory, it can be up to $150. If you need better pricing, it will depend on requirements and you need to write in.
Slurpy, hope this satisfies your queries. If you need more information please write in.
Fuzzywuz
Hi,
You may want to consider EasyN.
PAP
Hi all,
It seems that my existing DLink DIR-655 router has problem supporting all 7 of my cameras (mixture of DLink DCS-942L and DCS-5230L). It keeps crashing.
Anyone have any recommendation for a good wireless router for this purpose. Of course it must still be able to handle the laptop, mobile phone etc traffic.
I am considering the ASUS RT-AC66U or AC68U. Not sure they'll do the job.
Will be happy to hear any advice :)
Thanks!
