Is sineoji stable if the camera is not near router for a normal Hdb flat size?
My Fren kept complaining one or two of the xiaoyi is unable to view live as the internet connect seems weak and always detect the camera as being offline.
If sineoji or any other brand can overcome this problem will be great to do.
Its not just xiaoyi, all china's hosted cloud servers are recently having issues, many are not able to connect directly or instantly to the cloud. Also, our mobile networks connectivity is also kinda affected on such routing for IP cameras. Still the traditional DDNS works good for the advanced users.
Also, your routers plays a part too, some IP Cameras range is not that fantastic. And if your router's wifi keep fluctuating, then connection will be an issue. If you own an Android phone, download WIFI analyzer and monitor your wireless for 5 minutes, watch how your WIFI signal fluctuate at the area where the cameras are. It should not keep going up and down +-20dBm too often.
There's many factors affecting IP Cameras performance, cheap is not necessary bad. There is a special tread for xiaoyi in this forum. You can check out the resolution and the reviews there, even have someone hacked the cameras that it can upload to cloud of network storage.
