looking for about 4-5 fixed ip cam (prefer no pan & tilt to reduce cost), any recommendation?
Question;
1. Resolution required?
2. Wireless AC or N reqm?
Then one fine day, suddenly handphone and computer all cannot view
Question;
All was set up nicely. Have the camera like 1.5 years. I can view from my mobile at home and outside home, my work place computer.
Basics still applies.
1. Check camera status
2. Check Camera is connecting to router
3. Check router is sending to your phone (Or whatever)
Sounds like a camera prob. If all else fails, magic reset button? But you will need to re-config the settings. Not to difficult.
What brand and model again?
perform a reset via the pin-hole
check for new fw version.
If I use magic reset means have to reinstall the whole thing and I lost my installation cd
the CD is not needed lol.
any tools needed can be downloaded to Foscam's website
you can chat with foscam support, they will direct u to the correct page
Physically can we tell the model of the Sineoji ipcam by looking at it ? Saw it at every corner at my condo premises including the gym.
1-1.3mp will do, lan cable
I tried downloading on my iPhone but unable to open the zip file
for those using sinoeji 528, what's these buttons for?
tap on them, but nothing happened.
I guess you could start with Sineoji. So many happy bunny customers here....
The Dlink range with LAN cables are mainly at 640p for LAN connections. Which by todays standards, is pretty sub standard, esp if you have gigabit speeds.
Also their 720P ranges start above SGD 100, which is quite pricey, IMHO.
FYI, I checked out this brand called Dahua today in SimLim, apparently new in Singapore but making good progress in the UK. 3MP, POE, dome type, outdoor enclosure for SGD 150+.
My only concern with some brands is Firmware support, of which I am of the opinion that the "bigger" brands, seem to have a better grip of. Your milage may vary.
I came it to add, there is a chap on Carousell, who is selling HikVision, 1.3MP dome, LAN connection cameras 2nd hand. Am not related to the seller. And you buy at your own risk. But if you know how to deal with the connections, it should be a piece of cake at quite a good price.
oops sorry, must have missed that out while reading thru this thread.I have asked before, these buttons are for the outdoor cameras.
dahua is a known brand within china just like hikvision
ok, i not going to waste time.
This is HW0021 1080p version which i bought in Taobao which cost RMB270 (not included international shipping) ship vs 4px
If u want, u can get from this seller
https://wanscam1.taobao.com/shop/view_shop.htm?spm=a312a.7700846.0.0.86jnrl&user_number_id=451878979
I understand this seller review not much but mainly their business is at aliexpress
Ask for HW0021 1080p, dont bid the one which put on sale as this 1080p only sell when you ask for it. And remember to ask for 3pin plug (英规电源). As for DDNS label (DDNS标签) you need to request from them if nt they wont give as now most ppl use mobile app.
all these are take under normal circumstances which basic use at all house on normal usage.
Refer this to another model which i buy Wanscam IP camera HW0046 (960P)
http://deluxeforums.hardwarezone.com.sg/102438742-post4117.html
For SAFETY MARK Registered adapter:
U can get from here, it work fine as i am using this.
http://list.qoo10.sg/item/VSTARCAM-...ED-AC-DC-POWER-ADAPTER-UK-PLUG-WITH/423471132
http://list.qoo10.sg/item/SAFEVUE-SAFEVUE-IP-CAMERA-ACCESSORIES-FOR-IP-CAMERA-T6835-T6836/440700700
