Wireless IP Camera thread
Dave27
sineoji 716 is really cool..
I will be upgrading to a wifi mesh soon, setting up the sineoji cams will be the standard procedure I guess ?
hudarahmat
Sineoji
I had a very fruitful experience with Sineoji tech support! I was advised by myrepublic that i had to do port forwarding to connect my ip cam. alas that was not the problem at all when i was unable to connect to the ipcam via the mobile app. I whatsapped late night but amazingly still got a reply with clear and precise instructions. I have been trying to connect for a few hours but didnt want to reach out to tech support as it was late and didnt expect an answer. Very rare to meet such proactive tech support executives. We will be equipping the rest of our home with Sineoji now. :s13::s13::s13:
Hot2002
Hi, asking on behalf for relatives
If I purchase sineoji cam directly from their web store. Does it comes with installation? If not, What are the charges ?
Thanks !
guile
Thanks !
Hi you may contact Sineoji direct (Dean) at +65 8363 5195. You can call, sms or Whatsapp
barrios
Sineoji Camera is really good but its very low fps when viewing in Full HD sadly, is there any good 30fps IP cam recommendation?
You can set the fps to max 30 via WebUI but it will take up a lot of memory from your microsd card.
earthlink
You have to hard reset the cams first. Then you have to isolate the mesh. The rest are plain standard protocol , using the sineoji app to setup.
Don't forget to connect to the 2.4 band to setup.
earthlink
Mine has already been installed with Sineoji and so is my relatives too :s13:
vvaness40
Is the sineoji mounting done by adhesive or drilling ?
If you are using the mounting bracket povided in the box, drilling is required. If you don't wish to drill, omit the mounting bracket and use a 3m velco tape to stick on the base of the camera and to the ceiling to attach it.
donut88
Hi all,
Some recommendations needed
I want to install CCTV at my patio area. I staying at ground floor condo unit.
So I want to install CCTV to monitor the patio area.
Any recommendations on what kind of CCTV to get?
And how should the wiring trunking go?
How will the camera get connected to the DVR? I'm assuming the DVR will be placed indoor (maybe at TV console). How will the wiring be run? Must heck a hole through the wall to run the wiring?
My patio had power sockets for outdoor lights installer. Can tap power from there?
duckling
I have a Sineoji PT713V, how do I change my password for my account?
Many thanks in advance!
sgnimo
Tap on the settings icon which the small i symbol with a circle on the main page of the sineoji app. Then tap user , you can change your password from there.
TanKianW
Hi all,
Arlo Pro 2. Free cloud storage for 5 cameras and record roll-over for 7 days, excellent night vision, motion sensors, fully wireless, good enough battery life, magnetic mount, minimal technical knowledge required, mobile apps for android and iOS, optional local storage, weatherproof, built-in schedule, 2-way communication through mobile phone, smart home integration (work with Google Assistant, Amazon Alex, IFTTT), build in >100dbA alarm system on the wireless hub, integrated mobile phone/email notification.
aquanark
DCS2530L - camera reset by itself
Hi,
anyone using dlink IP camera? (DCS2530L)
after setting up the SD card storage per the instruction manual, the camera always reset by itself whenever i use the app to view.
Replaced the camera once, same issue occurred.
any advice?
earthlink
Kudos to Dean, how long did you take to complete these cameras installation in the warehouse ?
:D
posted on sineoji Facebook
