Of course if you are using third party app such as IP Cam Viewer, your sineoji camera is going through a 3rd party ddns server for streaming. That will depends on that streaming server. If that server resides in the USA, then you will have your camera streaming from Singapore to USA and back to Singapore, it is like frequent flyer miles.
Use the Sineoji app and it is fast and instant on your mobile data connection![]()
I still prefer Tinycam Pro app, it is really a top notched app.
Just want to know, how many of you are paid to post reviews for this sineoji, seems to be OVERLY positive reviews and seems to be the ONLY camera talked about at all.
Are there other recommendations? or is this really the most multipurpose brand out there?
that said can someone recommend me a pair of cameras under 150?
doesnt need to be wall mounted table top will make me happy
I also feel the same, machiam all work for sineoji![]()
I felt otherwise, such remarks seems to be a competitor of sineoji![]()
Hi guys happy new year in advance!
I've multiple sineoji cams installed in my house and it's working very well all thanks to Awesome Dean! Sineoji cams are really very responsive and good quality! Dean is also very helpful when comes to technical support and he will advice people patiently![]()
The cams actually helped and saved my dad's life twice recently as my dad is a stroke survivor who had two seizures in the middle of the night, the clear night vision infrared, capable of zoom in and good speaker/mic features allowed me to alert my helpers and saved my dad twice. The 1080p cams are really very clear and nicely made. I strongly recommend sineoji cams to anyone who wanna setup ip cam at home for monitor kids, elderly, helpers and security purposes.
Cheers
Alex.
Anyone knows how to mount new camera with old mount? Any workaround?
anyone can share dean contact?
I'm trying to mount PT714V onto the old mount. The new mount is some sort of a circular disc while the old mount is like 2 piece of sticks... Think you know what I mean .. lolBro which camera are you trying to mount ?
Thanks for the reply. Anyway I found a way to mount it on the old mount ******************The older mounting bracket for the sineoji cameras will not fit into the newer model of the sineoji cams like the 714v. Older bracket are more suitable for wall mount and the newer ones are ceiling mount. You can use the 3m velcro tape as an alternative so no drilling to the ceiling is necessary. That's the best option.
Need advice ~ Noob question regarding micro SD card for my 2X Sinoeji 716V.
64GB storage capacity have how many hours of recording? I don’t have any existing card to test. Will be using to check elderly, baby & maid @ home
Hi, how much does it cost to do the power point & trunking ? It is neat & nice
