Wireless IP Camera thread
Mecisteus
I have the Wyze cam pan as well.
It is good and cheap. They work with Google assistant - easy viewing on Chromecast and home hub.
They just introduced AI tech into the camera which would mean smarter detection - lesser notifications.
When it comes to software, firmware update and server, Amazon is a company you can trust.
You can see the Wyze forum is active with product discussion. Just like Foscam. That means you can expect good software update.
josephlpw
https://forums.wyzecam.com/t/privacy-concerns/14795
Privacy concerns? since backing up on Amazon also allows them to have options to view recordings?
Sent from Samsung SM-G955F using GAGT
Mecisteus
Between Amazon and some other IP cameras which provide cloud storage, I think I trust the former more.
Anyway, you can choose not to save in the server.
Apparatus
Arlo Ultra 4K Wireless Cameras.
Who is the distributor here or the major retailers here? COURTS, HN, BEST etc? Where's the tech support and service centre?
Apparatus
Found that Netgear and HN are selling the Arlo 4K wireless cameras.
There's a Arlo Singapore but no contact number leh
https://netgear.tech2cool.com/collections/all
https://www.harveynorman.com.sg/smart-tech-and-phones/cameras-en/security-cameras-en/netgear-ip-cam-arlo-ultra-vmc5340-100aps.html
https://www.arlo.com/asia/default.aspx
OK, no 4K streaming via 4G LTE. You get 1080p over 4G LTE. It also doesn't store 4K clips in the cloud. 4K only via home WiFi network
https://michaelkummer.com/tech/arlo-ultra/
shacboi
I have no issues with eyes android app.
Don't need to reset my cams at all.
Infact I use Tinycam Monitor Pro. Perfect for remote live viewing.
But I have to say the C7838WIP is one of the best Cams around. C7824WIP is really a budget cam but it has good low lux sensor.
https://drive.google.com/file/d/0B_80m_FzsV30T3ZfS3FSc3F0d1k/view?usp=drivesdk
Hi there, like to know how u connect ur vstarcam to tinycam Pro, I seems not to be able to get it connected the username and password u use is the eye4 acct?
I'm using C7824WIP model.
Greatly appreciated!
ksksksks
Got another wyze camera, wyze pan camera and their new motion sensor from Lazada :s12:
Mecisteus
My Wyze Cam is rock solid.
Switched on 24/7 and no hangup so far unlike my previous Foscam models.
Desmond:
I am using Sineoji 716v cameras after seeing all the positive reviews (apparently could be fake users, lol) and I must say that while the camera feed are clear and response time are good, the software is indeed lacking (fyi I'm using the old one, new app/software not supported by older cameras).
To play back the recorded videos stored in the SD card, I have to select 1 of many 10 to 15 mins video files under each camera. To make it worse there is no fast forward button. If you wish to locate an incident you have to waste a lot of time viewing each clip in their entirety.
Also, since last night my cameras (all 4) have been in the mode of "connecting" and "timeout". With a new maid at home this is not ideal. Hopefully the brand contact can help me resolve this soon.
CCCustom
Anyone knows of any consumer-grade (and cost) models from HikVision? Or are they all supposed to be commercial-grade (and cost)?
mmchaisi
Sineoji network seems to be down. I can see cameras if I’m in the network but not over the internet. Come on Sineoji.
mmchaisi
The software on mobile devices is crap, you have to use a pc to download the video file if you you want to scrub through the video.
mmchaisi
Hello Sineoji, have you gone bust? I can’t access my cameras over the internet. What’s going on?
epiphany01
2 days already
Sent from null using GAGT
Just got this
“Hi everyone, our network servers was down for the last 2 days, resulting on the remote access issue using your 4G data to access your cameras. As our network engineers has been working to diagnose the fault, please do not reset your cameras or uninstall your Sineoji app. As soon as the fault in the server is rectified, it will be restored. I apologize for any inconvenience caused and thank you for your patience. For sure, our engineers are currently working on it.”
