Wireless Printer
Extremme
Hi if my PC is at the red circled position and my wireless printer is at yellow location, possible to connect via wireless and print? Is it easy to configure?
Slowdown
Yes it should work. Provided you setup the two machines correctly. Wireless printer works on 2.4ghz. You need to make sure your PC is connected to 2.4.ghz wifi signal so that both of them can be connected together. They should both be on the same SSID.
peterchan75
It depends on where is your wireless router. It's best to connect your wireless printer to your router via static IP address. Can refer to your wireless printer manual on this. Just give it a try, and if works... OK.
Koenig168
The PC and printer are connected via the wireless network so yes, the arrangement can work. Just follow the instructions to configure. Quite straightforward when I did mine.
Extremme
Thks all. I will give it a try since its not too difficult it seems
wwenze
Wireless printers can be set to infrastructure mode also i.e. they connect to your existing wireless network
Signal strength might be a bit bad through two walls
Slowdown
As most PC and mobile phones are on 5ghz wifi connection and printers still on 2.4ghz, user is unable to connect the two machines together. I learned it the hard way. I must remember to change my PC connection down to 2.4ghz connection in order for both of them to be connected together.
Same for remote desktop connection between two machine. I was happily connecting my laptop and PC and suddenly one day I could not connect. Only after while I realized my laptop connected to my 2.4ghz band while my PC was still on 5ghz.
Because of this complexity I rather to use LAN port for my printer. Save the trouble and the worry about distance. Now I make sure all my devices are only connected to 5ghz wifi. Less headache.
Extremme
My router Wil be at the blue circled.
If my PC is connected to Lan at the red zone and the printer is also connected to Lan at the yellow zone,can it be connected too? All my rooms have Lan point
wwenze
Then just connect everything by LAN and forget wireless.
arthurkwan
Actually, don't quite understand why you are asking this question. You can actually run a test. If you have wifi connection in those places, you will be able to connect. Right?
PS: unless you connect your mobile phone via lan or mobile network all the time. = S
wongminmin
be it lan or wireless, as long your printer and devices connected to 1 single network.....u able to print remotely.
Northernray
The simplest and better way is to connect the printer to the LAN port, problem solved.
If you need more LAN port for that room, get a switch or grab a spare or old router and configure it as AP and use it as wireless AP and 3 port switch, you end up with printer connected, better wireless coverage and 3 wired LAN port, best of both world.
Extremme
Yup all rooms will have a RJ45 faceplate to accomodate lan points
Northernray
Exactly what I'm doing now in my office for years.
I need internet access in my rented office, the landlord's router no more vacant LAN port. Without a second though, go SLS buy a Dlink 4 port Giga switch, unplug the LAN cable to their shared printer and connect it to the 4 ports switch, run a 60m LAN cable from one of the LAN port on the switch to my office. Grab my spare WD dual band router with an internal 2TB hard drive to use as AP and 3 port wired switch. My Fuji Xerox wireless printer can now place in any corner of my office with enough wired LAN and wireless for all my devices. I can now use their A3 color laser printer if needed to (with permission), what more can I ask for with a $30 switch?
really_noob
My laptop is on the 5GHz SSID. Printer connected to the 2.4 GHz SSID. Both devices connected to the same router. I am able to print. I think as long as it is the same router, the laptop can communicate with the printer since they are on the same network.
Northernray
Both need to be on the same gateway and subnet, that's all.
peterchan75
Just try it out. Worse come to worse, just use LAN point if your printer supports it. The only advantage of having wireless printer is network cabling and it can be anywhere as long as it has good signal from the router. Just a word of caution. If your printer is inkjet, never ever switch it off and put it on standby mode. Otherwise, you will have clogged print head.:o
Extremme
Thks and noted the advice. I usually seldom use and will off it. Once a while print it to “warm” it haha
