All in a Day
- Jan 3, 2014
I'll let you know when my chelseas arrive
Thanks! Look forward to that!
BTW, question on use of shoe trees for Chelsea boots (i know CBS owns a pair if not anyone else).
I got myself a pair of chelsea boots recently and found it a real struggle to insert/remove shoe trees (removal in particular) to the point that it felt like overstretching the leather. I've since went back to using the original packaging paper stuffings instead.
Do you all have similar experience or tips (e.g. does the use of smaller size trees help)?
I have loafers and chukka which cannot fit the same size trees.
I use one-size smaller shoe trees as a result for those.
What shipping method and forwarder u used?Thanks for the feedback guys
@LHB i think my taobao game sucks. Got 2 pairs of trees from the seller u recommended n it cost me 38 sgd all-in loll. What did I do wrong?
I guess that's why there are boots-specific shoe trees with a smaller front piece and/or more modular pieces so where there are more moving joints.
Believe boot trees are designed that way to accomodate the shaft, which makes slotting in normal trees difficult + additional shaft support. Tree size wise the front portion is still the same as a regular tree for shoes.
Myself i prefer the woodlore style twin tube design when a lasted tree isnt available.
I guess most of us are using that too because that's also the most common taobao design
A peek into my chelseas...BTW, question on use of shoe trees for Chelsea boots (i know CBS owns a pair if not anyone else).
If I don't have shoe trees, would it be better to buy one or just use newspaper? Is there a disadvantage to using newspapers other than got to throw after one or two uses?
All the trees from me ah? =o
You, LHB, friends not on the forum...All the trees from me ah? =o
