Ok. It should be $254 excluding VAT
even cheaper coz exclude VAT
thanks for sharing
thanks for sharing
Hi seeking size advise for meccariello A190 last. Need to size up from normal uk size such as Loake capital last?
Thanks in advance.
Any interest in a jodhpur from Enzo Bonafe?
Model: jodhpur with buckle on the diagonal strap (right pic)
Colour: aubergine calf (left pic) with contrast? strap (yet to be decided)
Last: 773? Soft square last
Sole: millerighe rubber sole (left pic)
Handwelted
Others: if possible, bombe waist rounded on both sides
Planning to do through lusso, should be $800+. Great wet weather shoe!
does anyone know where to buy dress shoe laces?
Like to check where can i get sole protector or shoe tap for the rear sole?
Something like this but for bottom of shoe sole
https://www.google.com.sg/search?q=...QsAQIJw&biw=360&bih=525#imgrc=HrS3Pu64RYoDuM:
That's just a heel rubber pad isn't it?
You can have the rubber piece changed out at any cobbler.
Im referring to additional protection to our usual rubber sole to extend the lifespan of our rubber from wearing off too fast. Due to my walking habit, back heel wear off much faster than rest of the heel.![]()
Topy?Im referring to additional protection to our usual rubber sole to extend the lifespan of our rubber from wearing off too fast. Due to my walking habit, back heel wear off much faster than rest of the heel.![]()
It makes no sense at all. If you intend to add an extra rubber pad, why not just change out the worn out one instead? For all intended purposes, that's what the rubber on the heel was meant for (to be replaced when worn out). Last but not least, if you add additional rubber pads on your heel, it will alter the shoe height and balance, which will affect your gait and walking posture.
It's like wearing 2 pairs of pants so that the inner pair doesn't get worn out as quickly.
Yes something like topy protectors. Or some call them heel taps. They are made of more durable materials n last longer than our rubber or leather soles. The main idea is these are cheaper to replace than our rubber soles. A pair of vibram soles here will cost 55 to 60. Certainly not cheap in my books.
Some discussions here
http://www.styleforum.net/t/26871/do-you-guys-use-shoe-taps
Vibram/topy slap on half soles service is only going at $28 at Bishan j8. Unless you are actually referring to flushed metal toe-taps..
