Darknight55
- Dec 10, 2002
New J.FitzPatrick GMTOs look interesting. Gonna be another place to look out for interesting make ups.
Can I ask if u are a one pair of shoes guy or u alternateI have been a regular user of Pedro and Everest business shoe. I do lots of walking. These brands usually last me 6 months before it gives way. Would like to know if anyone has recommendation for more durable one without compromising comfort? Thanks.
Sent from OnePlus ONEPLUS A3010 using GAGT
My personal experience with loake1880 and herring has been good, less than 300 each pair after discounts. You may want to try them out. Mine is 3 years going and purchased online.Alternate between 2 pairs. Different colours.
Give way means what?
Soles drop out? Common for cemented shoes.
Heels worn off?
Leather cracked?
If heels worn off because you do a lot of walking can just replace the heel by cobbler.
For the rest, full grain leather gyw shoes will help you.
I have to admit I don't take care of my shoes the way you guys do. I seldom polish it. I tend to squat during site installation and the sole will break as times go by.
Why topy when he can buy a new pair of gyw with dainite soles.Comfort wise, I think you may find that the stuff that are being discussed here may not be as comfortable as what you are used to, especially at the start when you're breaking them in.
Granted that GYW shoes will likely last longer than what you have at the moment, you may need to consider adding topy to the soles since you mentioned that you use them at site installations. I'm not sure what the conditions are like at the site but leather soles may deteriorate faster under certain conditions.
You'll have to consider the cost factor as well. The shoes we recommend are likely going to cost 2-3 times of what you are paying now. Whether they would last 2-3 times longer, i'm not able to tell.
If you have some cash to spare, you can consider getting a pair to try out and have a feel of how long they last before deciding if you would want to go full blown on them. Carousell has a ton of shoes that you can get at a lower price to try out.
Might as well get redwing if you need a tough shoe their chunky thoI have to admit I don't take care of my shoes the way you guys do. I seldom polish it. I tend to squat during site installation and the sole will break as times go by.
Dainite soles would be more expensive to resole, assuming the upper survives.
