Working Shoe for Young Exec - Part 2
d4rkiez
anyone tried their hands on shoe patina? how do you achieve a striped effect like the picture below.
see https : // www .instagram.com/p/BQu5XiLDg4j/?hl=en
arcfire
Lots of time, effort and experimenting.
It's not something you can teach/learn in 1 forum post.
d4rkiez
I've tried a solid patina with burnishing at edges and another with mottled effect but always wondered how these streaks are done.
alvinquah
I have not done something like this before. But should look easy to achieve. My guess it's done via brush stroke on the finishing stage. The brush type, dryness of the brush with dye and strength play a part on the finishing.
I will test it out on a crust leather before applying it on actual shoe.
d4rkiez
Tks for your reply. I reckon the base layer should be the lighter brown while the darker shade of brown was brushed over it. The brush bristles should be rather hard and loosely spaced. Any idea what kind of brush fulfills this criteria? I am thinking of the Saphir pommadier brush. And the dye should be moderately dry before application. Will you dry the brush out after dipping into the dye?
alvinquah
Color wise I think your right about there... for brushes I am thinking flat brushes should work. Those from stationery store will suffice. Try to get those acrylic base type (black brush), easier to control.
As for drying before application, it's about trial and error. Again, do it in crust leather if unsure.
deathscthe
just hooted 2 pair of church's from london outlet for what i consider cheap price(ard 200pounds a pair). not sure if fullgrain or CG leather. anything i should take note of?
urbanturban
You can ask the shop about the leather.
If you use cream, and there is no absorption then it is CG leather.
In that case, use the wax only because cream won't work.
deathscthe
too late liaos. bought in outlet and now back in sg. anyway just whack cause at 200pounds the price almost same as retail loake. wear a few times then apply cream see how
deathscthe
The shoeboxes
Black dubai oxfords
com/g8q7aU0l.jpg[/IMG]
Brown oslo derby
Side by side
Sent from sent from limpeh phone to your screen using GAGT
WQtRiggEr
Managed to snag a pair of Carlos Santos tan brogues on sale at Skoaktiebolaget last week! About 195 euros ex-VAT and about S$20 shipping via Fedex for a total of about S$330.
Got a matching Carmina belt from the Capitol boutique yesterday for $130.
aspenx
I saw some nice half-brogues on Herring Shoes website. Want to go ahead and place the order after disappointment from EEA, EC (local also). However I'm worried about the sizing.
My most comfortable pair of dress shoes are a pair of Johnston & Murphy Optima Melton cap-toe oxfords in US 7.5.
I don't know if I should go for UK6.5G for Herring/Barker Lambeth or a UK7G for Herring Staverton. Is there anywhere in Singapore that I can try it out first before I place the order online?
RayeAng
Important to look at the shoes last. Different last will affect the size u take. U may visit orchard - hereen's Robbinson or metro at orchard centerpoint or taka to try out loake and barker shoes.
sartorial
nice belt.
