Working Shoe for Young Exec - Part 2
Emospence
Bros, I just went to BHG in Bugis yesterday and saw a shoe waxing set which cost $70.
Do you bros think its worth it to get that set?
I am still very happy with my SAF kiwi and brush though. :s12:
Can any kind brother advise?
Can only answer if you let us know what's in it.....
CustomMade
Appreciate all the replies..:o
(Please don't judge my location :/ haha)
Hey bros,
I'm a little noob when it comes to shoe shining.
Why is there that wrinkling/creasing on the captoe shoe? Any pro care to explain here?
iphone1s
There is a oval metal tin which looks like some butter cookie tin. And inside, there is a brush, various wax and all.
Do you all think its worth it? Seems a like a lot of work to maintain the shoes compared to a pair of shoes that can be simply kiwi-ed.
thundermarch
Hey bros,
TBH, I have been thinking about this picture for awhile now.
Typically, cracking of the wax looks obviously superficial. But in this case, the creasing / cracking looks like it is happening deep to the wax layer.
I would need to look at the shoes in person to decide.
One other possibility is that there is bad creasing of the leather, between where the toe puff ends, and the captoe seam. This is actually not an uncommon phenomenon, because the toe puff ends some distance from the seam, and I know (from previous experiences), that Meermin uses s**t leather. Sometimes, to most of the time.
JudeBox
Hey bros,
from what i googled.. it might be the case that the shoe is too long? or simply.. not a good fit.
JudeBox
it seems like its the bad creasing of the leather and the shine kinda "magnifies "it. sighhh i ordered this MTO because i really like how the boots looked.
I will remove the shine from the crease area and have no choice but to live with it.
arcfire
There's probably a few things that come to my mind, looking at where it's cracking. Fit is probable but it's quite a generic way to put it.
Length of the captoe can also play a part.
Creasing points like what you mentioned is also a factor. Different shoes on different feet will crease differently. Every shoe will be different.
arcfire
There's nothing to be sad about. You don't have to mirror shine the entire toecap to look good. It's knowing when to stop that matters.
Do a gradual shine from the tip to the vamp. It will still look great.
CustomMade
My sentiments exact. The wrinkling/creasing seems to be more than the superficial wax layer.
When i first saw the image without context to the shine, i thought it was the issue with the leather.
Good point with the toe puffs, yes, it is not uncommon for the toe puffs to end some distance from the seam and it is not necessarily a bad thing as the toe puff might be too stiff to some ppl.
Interesting thing about Meermin. Was actually considering their shoes....
Consider elsewhere.
Unless they're in your budget.
Honestly, I find Carmina's QC heading downhill. Yanko is decent and I find it on par with Carmina at a lower cost.
evangel21
I would actually recommend Carlos Santos over Meermin. Really decent leather and workmanship.
wiz
Had these for 3 weeks and they are just amazing can't help picking these all the time from my rotation :D
DT1212
Hi,
Any bros kind to provide update on Yanko shoe quality?
Am looking at Yanko Adelaide on 962 last, any bro own this pair?
Currently I am on UK 8 on Loake capital last, and consider should i go for same size for Yanko 962 last?
Thanks.
Hi,
Thanks.
Head down to Lusso and give it a try. They carry Yanko. Whether he has it in 962 last, which I believe so, better to give them a call to enquire.
Capital last is kinda generous and half sizes in UK sizing differs more than European sizes.
Thus I would recommend you trying it in person.
thundermarch
Hi,
Thanks.
Are you interested in 2nd hand Carminas? lol
staedtler_07
Hi,
Thanks.
Wonder where are you ordering from? Saw that Skyolax is the cheapest online so far, wonder if there is any place selling at a better price?
