Working Shoe for Young Exec - Part 2
CustomMade
Surfaces blemishes, minor scars, vein shadows, minor pitting, are all pretty commonly seen in RTW shoes that use full grain leather.
Normally, the best hides are chosen to be used for full grain leather.
Hides that are badly scarred in the first place, will be made into corrected grain leather.
Very often, this will still not ensure that the surface of full grain leather, is absolutely pristine.
Combined with the fact that RTW makers have to cut for economy, you can get surface markings such as these.
Very good point raised up by TM.
Leather is literally skin. And it is very challenging to find a perfect leather skin.
Even if they do find a perfect skin, they would not use the whole skin for a single shoe unless you're prepared to pay thousands.
The top grade full grain will usually be used for the toe cap and more visible part of the shoe while the middle or low range will be used at the back and less visible area.
This is a way to reduce the cost because not everyone can afford to pay thousands for shoes.
So yes, minor blemishes and pot marks are fairly common at middle range ready to wear shoe brands. Perhaps what is less common is that the blemish is right at the captoe and the most visible area.....
CustomMade
Hi all,I'm new to all this as this is my first job that require me to wear business shoe. Any idea what is a good amount to get a working shoe for? Any brand to introduce? I got a wider feet and hard time finding shoe. Thanks in advance
Recently I just gotten a $95 Blackhammer but end up too tight for me. Salesperson say will expend (today day one for me)
It depends on what kind of shoes you want.
For an entry level shoe, a cemented shoe would be good. As long as it is not more than $150, it is reasonable for cemented shoes.
If your budget is higher, you can try a Blake stitched shoes. You can expect to pay between $200 to 400, depending on which brand.
I would recommend blake stitch for your very first pair as it is relatively easy to break in due to its lightness and flexibility. Plus it is fairly durable as well.
If you have wide feet, remember, always size for your width first, even if it means your shoes are slightly longer.
It is tempting to see that space at the heel area and get a size down but the width is always more important than length.
I see many guys that come by to my office for fitting pay excessive attention to the back of the heels...
DT1212
Hi,
Can someone give a recommendation how can I polish it to make the spot less visible?
I tried many layers of Sahir Pate De Luxe polish and still no improvement.
urbanturban
Hi,
Don't fret over it too much. Wear, then wax and brush. Repeat.
After a while, it will go away.
theblueark
Hi,
There's very little you can do unless you're willing to sand down and redye the leather. I've learnt to live with some of the battle scars. You can smooth them out with wax but the scuff will likely still be visible.
This is the best guide I found in the past: https://www.hangerproject.com/shoe-care-guide/how-to-repair-scratched-shoes/
Dynosaur
Yup! I've placed orders for two more Loakes!
Will kena 7% GST on arrival?
I called Metro, they said promo over last sunday. lol I missed by one day.
Anyway I'll order from Robinsonshoes too. Which two more Loakes did you order bro?
I'll just rock with my AE First Avenue for my immediate need. Hope it's okay for the meeting dinner.
harlequin2902
Aldwych in brown and Buckingham in tan.
methoddingo
There's a new shop selling customised shoes opening at Telok Ayer.
They were featured in ST today, showroom opening at Telok Ayer soon. $300 up a pair.
http://custommade.com.sg/
*Edit: I just realised the seller most likely just posted in this thread too. haha.
supernova
Curious, do you do stuff like toe taps/topy etc? Currently the only place in singapoee to do proper flushed metal toe taps (that do not cost $120) is ed et al.
CustomMade
Haha, yes! That's yours truly here!
We're considered the new kid on the block. Woot! It was a fun photo shoot.
2 hours of my best "looks and poses"...damn man..being a model aint easy.
We're re-opening on the third week of May, will be throwing a one time only opening promotion!
darthsid11111
Hahaha, Thanks a lot bro!
Yea, i did come a long way but there is a much longer route to go!
My vision is to bring a local singaporean shoe brand to South East Asia!
I think Ed Et Al's already done so, unfortunately. However things seems to have gone a little off the rails there.
Btw any plans on utilising the Blake rapid method any time soon?
Sent from Samsung SM-G930F using GAGT
