Working Shoe for Young Exec - Part 2
thundermarch
Yes, indeed, taking into account GST, Lusso's EBs are priced equivalently to SkoaB.
As to good shoes that can only be bought in Italy. Well, there aren't many I can think of, given the wide distributorship of shoes of any make, due to various online retailers popping up everywhere.
There are some interesting Italian bespoke makers that are pretty difficult to get access to outside of being in Italy, like Bocache and Salvucci. But this will likely be outside of your budget.
One also has to take into account the fact that you need to pay VAT when buying Italian shoes in Italy. Even though you get a VAT refund at the airport, the refund is only partial.
I would suggest though, if you are near Naples, to visit Antonio Meccariello, to try on some stuff and get an idea of his sizing at least, look his works, and who knows, there might be some good deals there. His Argentum RTW line is within your budget.
One Italian RTW maker I find quite interesting, that is as of now, still quite difficult to get outside of Italy and Japan, is Bettanin & Venturi. Their earlier styles were very loud, focusing on thick, chunky norvegese models. But they have recently expanded their lines to include dress shoes.
If you are in or near Florence, there is this maker, Ducal, that has also been on my radar. The work looks fairly decent, possibly on par with what Bonafe offers, but I cannot say I have first hand experience, primarily because they are very hard to find outside Italy. Construction methods range from Blake (both BS and BR), and handwelted. If you manage to buy a pair, let me know.
lalalia
Alright thanks for the reply! Will update you if I manage to get my hands on a pair there :)
ducky_88
How can I prevent or remove winkles on e shoe?
theblueark
Whenever you are not wearing them. The idea is that as you wear your shoes in the day, it starts to collect moisture from your sweat, and the leather creases at the places your feet bend. So when you get home, you put the shoes in the shoe trees. This straightens out the shoe close to its original shape and helps to dry the leather.
Ideally you should let the leather dry and rest in this position for at least 24 hours, which is why it's a good idea to have 2 pairs of shoes at least to rotate.
theblueark
By the way, it looks like you're making an unbalanced knot.
Try this: Reverse the starting knot. If you've been doing left over right, change it to right over left, or vice versa.
Then do the 2nd knot with the loops however you usually do it.
You should end up with the loops and ends nicely symmetrical on both sides of your shoes.
ducky_88
Leave the shoe trees in your shoes when you are not wearing them.
Thanks for sharing.
My shoe tree has not arrive yet. Guess I just use the moth ball to absorb those moisture.
Amazing to know that you can even tell how the way I tie my laces. Will try your method. Thanks.
All in a Day
Personally, I am skeptical about absorption of moisture being something that shoe trees are designed to do / capable of doing. But I am no guru.
However, there is no doubt shoe trees help to minimise creases or at least delay the eventuality of creases setting in, and ultimately contribute in prolonging the life of the shoes' upper, all else equal.
wiz
Another use of shoe tree is to stretch and slight expand those shoes which are too tight
theblueark
I guess we know wood definitely absorbs moisture. The question is whether the cedar is attractive enough to the moisture from the leather to absorb it any faster than it would naturally dry from the atmosphere.
Maybe someone will invent a shoe tree that has a compartment for replaceable silica gel. Or disposable Thirsty Hippo shoe trees? :s13:
All in a Day
Many high end shoe trees are actually lacquered/laminated hence my doubts on absorption of moisture.
The idea of building in a compartment for dehumidifier is pretty interesting!
